KZ/GPZ mono shock hack was Budget Turbo Build
- lushbaugh
- everybodys a pro......
Re: Budget Turbo Build
27 Dec 2012 15:55
its coming along, just make sure that welder is penetrating good and you spot it in before running a bead so it dont warp. thanks for taking lots of pics
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- wireman
31 Dec 2012 05:54
Im no machinist either,just a plumber with a welder and a tape measure and a die grinder! :laugh:
- kzz1king
11 Jan 2013 23:30
Well I had to grind off the tacks and remove everything I had on! I should have done a better job of triangulating the top mount,swingarm pivot and bottom mount. First the shock was hitting the front of the arm so I thought I could move the top mount to the rear a bit. Then I run into trouble when the shock was short end of travel. Got it worked out I think. Going to take it all back together tomorrow.
I scored some GPZ 1100 adjusters so I can use my stock axle
Stock axle is to short for this arm
Back to ebay for an 1100 axle I guess.
Wayne
Wayne
Home built KZ1000 turbo setup
- Hollywoodmx
12 Jan 2013 02:10
Perhaps you aren't building enough pressure. If your not getting boost your not even opening the wastgate. I thought those mitsu t25s used high boost stock. Are you building vacuum even?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- kzz1king
12 Jan 2013 11:19
I had did have vacuum. I sold all the stuff and am going back to carbs. I need to change the title of this build thread but am unsure how to do it.
Wayne
Wayne
- Puffin
12 Jan 2013 13:55kzz1king wrote: I had did have vacuum. I sold all the stuff and am going back to carbs. I need to change the title of this build thread but am unsure how to do it.
Wayne
Try going to your/the first post in this thread, go to edit then change the subject title. That should work here no trouble
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
The following user(s) said Thank You: kzz1king
- kzz1king
12 Jan 2013 14:05 - 12 Jan 2013 14:08
I have been trying to figure out the shock/swingarm clearance. I tried bolting it up leaving the top mount off but then the shock moves up and down. Looked like it would work but was not sure. I then came up with this
. Made everything clear in my head. The bottle is a tad larger than the shock, got the bottom mount where I thought it shoud be and did same with top. Moved arm through it's range. Hopefully I have it now.
Attachment DSCN2105.JPG not found
Last edit: 12 Jan 2013 14:08 by kzz1king.
- ramtough_63
Re: KZ/GPZ mono shock hack was Budget Turbo Build
12 Jan 2013 14:45
cant nwai to see it come together
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- kzz1king
14 Jan 2013 00:54
Slowly but surely Ram, thanks. I went out tonight to weld it all in as I think I finally have it ready t go. Going to do a few tacks and check it again. Anyway I get out in the shop and it seems a bit cool. The furnace had quit on me. It is zero and going down so I had to work on it. Hopefully a new transformer will get it going again. I have my fishhouse heater going ow so hopefully will keep it above freezing.
Wayne
Wayne
- wireman
14 Jan 2013 01:08
Do you have 24v coming from transformer,line voltage to transformer?
- kzz1king
14 Jan 2013 01:38
I pulled the transformer to double check. Hooked 110 to line and it showed no output.
Wayne
Wayne
- wireman
14 Jan 2013 14:13
If you were close to Nebraska ive got a few laying in the garage depending on what style it is
