Doctorot's '78 KZ1000 build
  • DoctoRot
  • DoctoRot's Avatar Topic Author
Re: Doctorot's '78 KZ1000 build
01 Aug 2025 00:37 - 01 Aug 2025 01:43
#915397
I'll probably go with the bearings from APE since they are a fraction of the cost of OEM which is just NTN/NSK bearings anyway. I inspected everything closer tonight and the only damage I can see is some slight burnishing on the shaft where the bearing sits. I can't feel any imperfection and the other bearing fits on there perfectly with zero slop.
Last edit: 01 Aug 2025 01:43 by DoctoRot.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
01 Aug 2025 00:41 - 01 Aug 2025 01:29
#915398
IMHO as long as the debris is out and none of the gears are chipped I see no reason for it to not "go again" - could have been soooo much worse
PS: what does the clutch look like after those 5th gear pull aways ?
Last edit: 01 Aug 2025 01:29 by Wookie58.
  • DoctoRot
17 Sep 2025 23:49 - 17 Sep 2025 23:50
#917328
back in action
Last edit: 17 Sep 2025 23:50 by DoctoRot.
The following user(s) said Thank You: Nessism, Wookie58, Kelly E
  • TexasKZ
  • TexasKZ's Avatar
18 Sep 2025 13:10
#917350
Yay!
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
19 Sep 2025 10:58
#917384
That looks like the 7/11 on Nickerson. Did they move the Backfire Moto again?
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • DoctoRot
19 Sep 2025 13:07 - 19 Sep 2025 13:08
#917387
 It sure is. Moved to 2- kick coffee off Nickerson. Cheapest beer prices I have seen in the city. I’ve been to bike nights all up and down the west coast and I think backfire has the most interesting mix of bikes.
Last edit: 19 Sep 2025 13:08 by DoctoRot.
  • DoctoRot
07 Jan 2026 01:26
#920392
I was never totally happy with the Tarozzi rear sets on this bike. The peg location was too high, too far back, and too wide for my liking.  The levers were too short for my size 13 feet and the angle of them meant I occasionally pushed them unintentionally with the side of my foot dragging the rear brake. On top of that I didn't like how chunky they looked.  Pretty much the only things I like about them were the mechanism to keep the kick-start I developed and the rubber on the pegs.
Last year I did a control system retrofit  and complete re-wire on a Bridgeport Boss CNC knee mill. Ive been teaching my self CNC machining and this project really pushed my ability to design, engineer, program, and manufacture these parts. I learned a lot along the way.
I still need to anodize them and modify the kickstand for clearance but they are functionaly done.
The following user(s) said Thank You: Nessism, sf4t7, Dragbike_Mike
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Jan 2026 01:47
#920393
Top shelf work as always Doc, I love them. Aftermarket generally looks "aftermarket" but custom pieces like this look like they belong. This is the sort of standard I would expect to see from the likes of Bimota
The following user(s) said Thank You: Nessism, DoctoRot
  • Nessism
  • Nessism's Avatar
  • Away
07 Jan 2026 03:58
#920394
Outstanding work Doc!  Love the articulation for kick start clearance.  The design and fabrication shows inventiveness and skill!
BTW, is that mill in your home workshop?  Or, are you doing some after hours tinkering where you work?  Where I recently retired from, we had two different CNC Brideports, older versions than yours I think.  Made in the 1980's.  The control systems were aging on ours.  Had to bring in a repair contractor a time or two, to replace PCB's and so forth.  Bridgeport is no longer supporting with PCB's, but there is some company that refurbs the boards to keep the machines running.  Our machinist loved them, regardless.  Even for simple tasks, he used the CNC instead of the manual Lagun mill we also had.
  • kimchella
  • kimchella's Avatar
07 Jan 2026 08:36
#920397
Great work Doc, just shows that you are never too old to learn new skills and techniques. The outcome looks awesome.
Rich.
KZ650B1 frame number 225
New Zealand
  • DoctoRot
07 Jan 2026 12:18 - 07 Jan 2026 12:36
#920405
This is in my home garage. This is an early 80's Bridgeport Boss CNC fitted with a Heidenhaine control system. This originally was in use at Nasa's Jet Propulsion Lab in Pasadena so primarily used for prototyping and has low hours and wear on it. I retro fitted with Centroid CNC control system and upgraded a bunch of the components while i was at it as well. I also added a VFD for the spindle motor so I can run this on single phase power.
Last edit: 07 Jan 2026 12:36 by DoctoRot.
The following user(s) said Thank You: Nessism, Dragbike_Mike
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Jan 2026 12:42
#920406
Puts a whole new slant on the term "shed build"
