Doctorot's '78 KZ1000 build
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Doctorot's '78 KZ1000 build
28 Jul 2025 07:47
#915163
I can't imagine a builder of Doc's skill is running the chain too tight - however he isn't shy in the "burnout" arena
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
28 Jul 2025 07:55 - 28 Jul 2025 07:59
#915165
The doc wasn't the address this was addressed to...I meant maybe a previous owner, most of us aren't the first owners of our bikes....anyway: a bearing that's sooo a kind destroyed must have a cause, it doesn't happen on its own!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 28 Jul 2025 07:59 by MFP-Joe.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
28 Jul 2025 09:05
#915171
WA-20 is always a treat
Hwy 20 is a great road and the Washington Pass hairpin is my favorite corner especially westbound. I can take that corner westbound at 60mph on the Concours. Eastbound is off camber and regularly has gravel on the road. Just about every trip we take the first and last day is riding Hwy 20. Lunch in Winthrop at 3 Finger Jack's or on the deck overlooking the river at Carlos 1800 Mexican restaurant.
Now I need to plan another trip over Hwy 20.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • DoctoRot
  • DoctoRot's Avatar Topic Author
28 Jul 2025 10:43 - 28 Jul 2025 10:55
#915181
Unsure as to why the bearing failed. These are the original bearings so that means they have about 90k miles on them at this point. I regularly beat on this bike – burnouts, clutch dumps, I hit the rev limiter everytime I ride it.
Since this bike is jacked up in the rear and extended swingarm I determined chain slack by removing the shocks, finding the tightspot in the swingarm arc, backing it off a bit. I then made a gauge block that I use to set chain tension.
It looks like all the balls are still in the bearing - I count 11, the gap is what the cage typically takes up if it were there.  I'm considering a double row bearing from APE.  www.kzzone.com/trans.html
Last edit: 28 Jul 2025 10:55 by DoctoRot.
  • asphalt900
  • asphalt900's Avatar
28 Jul 2025 12:32
#915185
No need for the Fancy Expenditure DoctoRot! I've plenty of "little" more powerful engines i've built over the years that don't ever require that option of double row output bearing. I believe ZED1015 mentioned an option for output bearing. They are still a 6000series bearing but if you look inside they have a draft/windage area not that that that would matter.
  • MFP-Joe
  • MFP-Joe's Avatar
28 Jul 2025 12:40 - 28 Jul 2025 12:41
#915186
Can't do more than what you did to determine the correct sag..1 Perhaps a material defect or fatigue of the bearing's ball cage?...and at the mileage about 145000 km´s , everything can happened....!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 28 Jul 2025 12:41 by MFP-Joe.
  • asphalt900
29 Jul 2025 07:43
#915207
90K is a crap load of spinning. I Always replace these when going thru an engine. Also interesting, have you ever witnessed a "plastic" cage/separator in the newer bearings? I do a lot of chainsaws and for some reason Stihl decided this a cheaper way to assemble? I see them fail at an alarming rate, at least when the cage goes south it doesn't eat-up the ports.
  • DoctoRot
29 Jul 2025 23:50
#915256
Engine pulled and cases split.  Everything looks OK. It appears that i caught this bearing issue fairly early on. I'm going to replace both roller bearings on the trans, should i replace the needle bearings as well? looks like the outer race for one of the needle bearings is NLA.
  • MFP-Joe
  • MFP-Joe's Avatar
30 Jul 2025 00:03 - 30 Jul 2025 00:50
#915257
Hi Doc,I would replace all the needle bearings, given all the wear and tear and small metal particles you showed us in the oil pan!
(It would be a shame if you had to redo the whole process because of another damaged bearing, so maybe it's a good idea to think about it, right?...and hope and cross my fingers that nothing has gotten between the rollers of the crankshaft's main bearings!.
I wish you the best of luck getting the engine back on the road!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Last edit: 30 Jul 2025 00:50 by MFP-Joe.
  • asphalt900
30 Jul 2025 02:33
#915258
Might be NLA but they are out there Doc. I have cleaned-up spares for a lot of the different 72-80 style trans clusters. Big thing is of course, new roller and outer race are only as good as the shafts they are running on. I'm sure you're going to inspect but make sure your shafts are worth the money you plan on spending. Do You have the Mark2 trans or something different?
  • asphalt900
30 Jul 2025 02:54
#915259
Which one of those puppies are you having a hard time to finding  ?
The following user(s) said Thank You: MFP-Joe, Gdizard
  • asphalt900
30 Jul 2025 08:16
#915284
Not to be snarky Doc but You reminded i needed one of those bearings too!! Think i got the last one OEM one on ebay, ha. Rebuilding a Z2 Engine for a Friend in Virginia and he likes new shite.
