Bobbin my KZ1000 LTD
  • Proxy
  • Proxy's Avatar
  • 80% Human 20% Nuts/Bolts
Re: Bobbin my KZ1000 LTD
21 Apr 2011 16:08
#446099
Looks good...
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
  • TNBOBBER
  • TNBOBBER's Avatar Topic Author
21 Apr 2011 17:14 - 21 Apr 2011 17:17
#446111
I like it, and the pin stripping would be pretty sweet and change the plug wires to red too. Thanks guys.
Sometimes God doesn't calm the storm, He calms us in the storm.
Last edit: 21 Apr 2011 17:17 by TNBOBBER.
  • TNBOBBER
23 Apr 2011 17:10
#446547
I finished painting my wheels this morning. It looks just like the pic Proxy worked up. I'm going to attempt to do some type of red and white pin striping before I post a new pic.
  • TNBOBBER
23 Apr 2011 22:08 - 23 Apr 2011 23:30
#446588
Went crazy with the pin striping, what you all think. I'm undecided, not sure if I like it or not.
Attachment DSC01584.JPG not found
Attachment DSC01587.JPG not found
Last edit: 23 Apr 2011 23:30 by TNBOBBER.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
24 Apr 2011 09:28
#446676
i like the pin stripe tnbobber.
i think it looks really good and fits the look you are going for.kinda brings it all together.
imho,sir.
  • Proxy
  • Proxy's Avatar
24 Apr 2011 10:06
#446687
Striping looks great. I am sold on everything except the tail. Sorry but it just seems a little too bulky for me. There are angles that I like it from(front). I can see how some would like it tho. I also never cared to see the brake line splitter and cables. I don't expressively like the Kaw cover that is used to hide them but it is better than nothing IMO. I kinda do like the all black ones. All in all your bike is one of the best I have seen I like the fab work and theme. You put it together pretty fast and got some great results. You gotta be proud!
  • slickjr82
  • slickjr82's Avatar
24 Apr 2011 22:29
#446840
HEY JUST FOUND YOU BIKE LOOKS GREAT LUV THE FORWARD CONTROLS I AM CURRENTLY BUILDING A ONE OFF KZ 1000 CRUISER WILL POST PICS LATER WAS WONDERING IF YOU USED THE STOCK RECULATER RECTIFIER SET UP OR AN AFTER MARKET AND DO YOU HAVE A SCHEMATIC FOR JUST THE BASIC CHARGING SYSTEM
  • TNBOBBER
25 Apr 2011 09:28
#446897
Hello slickjr82, I did use my stock setup with the regulator/rectifier. On my B4 LTD it's was real simple, 3 yellow wires go to the reg./rect., the black w/yellow stripe goes to ground, the brown goes to 12+v and the white w/red stripe goes to 12+v. I put both my 12+v circuits on a 30A fused/switch circuit. So far no issues and charging 13+ volts. I hope this helps, can't wait to see your project.
  • Betraying HD
  • Betraying HD's Avatar
25 Apr 2011 22:42
#447036
man I like it but since you chopped the tail off you should have flipped your controls the other way. or just used em as highway pegs. Me personally, Like to be able to tuck into mike bike when I am pushing her pretty hard. (I have an 82` 750 LTD) like some parts of it though. Kool bike
  • TNBOBBER
27 Apr 2011 19:48
#447428
Can't get use to the pin stripes, they had to go. They were to loud for me. I'm to old to be pushing her hard (Betraying HD), I'd rather stretch out and cruse. I'm 6'4" and my knees aren't the best anymore. I'm planning on doing something else with the tail for sure and may be more. Some more of you guys working on projects need to post them on here. I enjoy just checking out what everyone is doing.
  • z1kzonly
  • z1kzonly's Avatar
28 Apr 2011 00:38
#447479
Paint the front fender black too!!
Put some rubber fork tube boots on the legs too!
Thats what I would do to finish er off!
  • djturnz
  • djturnz's Avatar
28 Apr 2011 07:51 - 28 Apr 2011 08:19
#447511
To me that chrome front fender looks out of place with all the black around it. It also looks too stock. Maybe shorten it at both ends and make it look as minimal as possible, while still being a fender.
For the brake line splitter, I folded a black bandana up like a 3inch wide headband, and tied it around my forks to cover the brake splitter.
For the rear, I say lower it a bit. If your springs are rusty anyway, cut a full coil off and powder coat them. Then get a shorty rear fender and mount it to the swingarm. That would be more in tune with a bobber look.
If you look at pics of bobbed Sportsters, a lot of them rotate the stock rear fender up so it ends at the 12 0'clock position and the flare looks like a duck's ass. That could work here.
Also, if you are 6'4", maybe get some taller bars? I like to sit up, not lean over when I ride. I have 12" apes on my 750 LTD, but even some 6" Z-bars would straighten you up a bit.
Just my 2 cents.
EDIT: This is "sort of" what I am talking about with the rear fender. Not the picture I was trying to find though. This on is frame mounted. If you went with a bit longer fender, and swingarm mounted it, it could hug the tire.
1982 KZ750 (4) LTD
Last edit: 28 Apr 2011 08:19 by djturnz.
