The start
  • DoubleDub
  • DoubleDub's Avatar
Re: The start
21 Feb 2011 06:59
#432325
PLUMMEN wrote:
ouch,that hurts! :laugh:
ive told omr to show up with a ryder truck on many occasions to lighten the load,but the ol pussy dont like snow! :laugh:
I'm on the way...
  • PLUMMEN
  • PLUMMEN's Avatar
Re: The start
21 Feb 2011 08:35
#432341
damn snows coming again! :(
  • DoubleDub
Re: The start
21 Feb 2011 08:58
#432344
I got the chains on... :P
  • PLUMMEN
  • PLUMMEN's Avatar
Re: The start
21 Feb 2011 09:07
#432345
well bring some doritos/mountain dew,incase we get snowed in down there! :laugh:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: The start
22 Feb 2011 05:57
#432641
single sided swingarms are cool and all :laugh: ,
but
i wanna see what your gonna do to the z1r!
  • jus1975
  • jus1975's Avatar Topic Author
  • www.tripleaperformance.com
Re: The start
22 Feb 2011 08:56
#432678
z1r wont be till I finish this one. Cant have too many projects and i already have way too many. It wont be single sided. So hopefully in a few months I can get started on it. God willing and the creed dont rise.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: The start
22 Feb 2011 09:15
#432682
oh i think there will be enough on this one to keep our attention until the z1r get sits place on the table.:silly:
  • jus1975
Re: The start
22 Feb 2011 10:30
#432691
your right about that. its just hard keeping focus on it. Just have too much going on
  • 531blackbanshee
  • Vendor
  • Vendor
Re: The start
22 Feb 2011 11:40
#432710
believe me,i understand where you are coming from.
  • jus1975
Re: The start
01 Mar 2011 19:40
#434325
[img] new update started with reverse engineering the hub. Took apart the Triumph hub and I noticed something. Hopefully one of you can tell me why is it that one bearing is smaller than the other in the hub and why is one a roller and the other a needle bearing. My plan is to use two roller bearings with the same ID but bigger and maybe wider to handle a heavier load. What do you think about that? And where the axle is splined maybe a larger spline. I am going to design the cush drive from a ducati instead of a triumph. (looks better). This is the first time Ive used a CAD program. Coming along fairly easy. I just have to figure out how to do the axles with the splines and the rotor mounting. Or come up with something easier. The way it is now will probably be expensive to machine. I welcome all ideas [IMG]http://i297.photobucket.com/albums/mm236/jus1975/33.jpg[/img]
  • PLUMMEN
  • PLUMMEN's Avatar
Re: The start
01 Mar 2011 19:50
#434331
totally beyond me! :laugh:
  • kawman14733
  • kawman14733's Avatar
Re: The start
03 Mar 2011 15:54
#434763
531blackbanshee wrote:
when i built my custom swingarm to fit a 200 mm wide tire and r1 wheel the main thing i did not want to do was modify my frame,at all.
so if at a later date i wanted to put it back to stock i could.
i was succesful to,and i believe that you will be also.:)
keep us posted,
hi how did ya get the chain to clear the fram and tire and retain the stock chain cover to clear a 200 mm tire ///// what offset front sprocket and is the tire centerd with the tail fin.. thanx steve
