The Mosquito!
Re: The Mosquito!
17 Mar 2011 19:22
#438695
I would use black on the side covers and a tiny bit of red on the tank. Actually, many moons ago that was my BSA color scheme. Ed
Re: The Mosquito!
17 Mar 2011 19:22
#438696
Last incarnation of same BSA...
  • scott s
  • scott s's Avatar Topic Author
Re: The Mosquito!
26 Mar 2011 20:07 - 26 Mar 2011 20:10
#440633
To make a mount for the Mojave tank, my Dad bent up a strip of metal to match the rear curve of the tunnel.
Last edit: 26 Mar 2011 20:10 by scott s.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:15
#440636
We then cut a mushroom shaped piece of metal that the band will be welded to. The tank came with a rubber strip across the rear, so this mimics the way it would have been mounted on a Bennelli or Ducati. There's a hole through the tank at the front and we'll weld a nut to the backbone and simply bolt it down.
This is the way many bikes have the tank mounted, an Rd350 for example. It also makes a neat place to mount the regulator/rectifier.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:18
#440638
The tank is much wider at the front than a stock KZ250 tank and the clip ons would have hit it at full lock.
We welded a couple of nuts on each stop, then cut off a bolt to fit in the nut. We cut a slot in the end and now we have adjustable stops. Once the bike is finished and everything is hard mounted, I'll probably put a dab of blue loc-tite on the threads and set them where I want them.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:20
#440639
Here's a pic with the shortened seat and the rear tank mount. The front of the tank may come up just a tad...we'll probably put a rubber snubber between it and the backbone, but this is pretty much the stance.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:22
#440640
We bent up some metal and made some braces for the tail light mount.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:23
#440641
Drilled some speed holes....
  • scott s
Re: The Mosquito!
26 Mar 2011 20:24
#440642
And got the tail light mount all fabbed up.
  • scott s
Re: The Mosquito!
26 Mar 2011 20:25
#440643
Tucks in real nice from the side view, but still plenty visible from the rear.
  • rslingshot
  • rslingshot's Avatar
Re: The Mosquito!
26 Mar 2011 22:58
#440652
Great fab work, looks killer.
  • scott s
Re: The Mosquito!
01 Apr 2011 18:33
#441991
I forgot that I haven't posted a pic of the powerplant since we got it all reassembled and paint detailed.
