The Mosquito!
- scott s
Re: The Mosquito!
19 Apr 2011 09:24
The tank, while mounted firmly, still had a little side-to-side wobble. I wasn't happy with that, so Dad came up with this solution. This makes the tank much more secure and still gives just a little.
- TNBOBBER
Re: The Mosquito!
19 Apr 2011 10:07 - 19 Apr 2011 12:33
"You mean the arm the linkage bolts to? Why do you say that? What happens when it's too short? The bike's not running yet, but it seems to operate the brake just fine."
Yes, the arm the linkage bolts to. You won't have enough leverage to apply the pressure you'll need to stop. At 6" it feels like your standard brake, but like mine, 4" you have to struggle some what to stop. The length you've got, will be a serious problem. You can wait till you get it on the road and see what I mean, but be careful.
Sometimes God doesn't calm the storm, He calms us in the storm.
Last edit: 19 Apr 2011 12:33 by TNBOBBER.
- scott s
Re: The Mosquito!
19 Apr 2011 10:34
Will do. The arm on the back of the linkage is still the stock length. I can lock the brake up very easily as it sits, but that's not at speed, of course.
- scott s
Re: The Mosquito!
02 May 2011 17:19
We needed a dash to mount the key, so we cut up some scrap metal, bent it to shape and sprayed it with wrinkle paint.
We used some existing threaded holes on the triple tree to mount it.
- scott s
Re: The Mosquito!
02 May 2011 17:20
...And...bodywork has begun. I'm going to paint this one myself. I've had some pretty decent results using spray bombs and Maxx2K 2-part clear coat in a can.
- gengomerpyle
Re: The Mosquito!
02 May 2011 17:26
its coming along great. cant wait to hear it run
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- scott s
Re: The Mosquito!
02 May 2011 17:54gengomerpyle wrote: its coming along great. cant wait to hear it run
Me either! We're going Thursday to have the exhaust fabbed up. It's gonna be cool! You won't believe what we're using to make the megaphone!
- scott s
Re: The Mosquito!
08 May 2011 19:46
Finished the bodywork and painted the tank and seat. This is a spry-bomb job, done with Dupli-Color and SprayMax 2K clear coat.
- scott s
Re: The Mosquito!
08 May 2011 19:50
For the exhaust, we used the stock head pipe and this stinger...from a VW Beetle! We cut of the three bolt flange and made a hanger bracket.
- scott s
Re: The Mosquito!
08 May 2011 19:51
Then had our local muffler shop weld up some pipe. For a baffle, he cut a piece out of the innards of a Corvette side pipe! Fit's perfect.
- scott s
Re: The Mosquito!
08 May 2011 19:52Please Log in or Create an account to join the conversation.
- Sackman
Re: The Mosquito!
10 May 2011 14:10
Very nice pics and tutorial on the build. Also it's great that you can spend time with ur pops in the garage!
Check out my blog at backyardbikechoppin.blog
or
Sackmans Choppers
77 KZ 650 Chopper
84 Honda Nighthawk Chopper
98 Vulcan 1500 Classic
or
Sackmans Choppers
77 KZ 650 Chopper
