Tale of an SR650.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Tale of an SR650.
27 Feb 2012 11:12
#506642
that is going to look WICKED! :evil:
what bike is that shock off of ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • M357.5
  • M357.5's Avatar Topic Author
  • Kwakas N' lots of em'
27 Feb 2012 15:14
#506659
Shock is an Ohlins, off a Ducati 900SS. The 900SS has a cantilever style swingarm/shock layout, so thats why I went with it. I had a guy measure the ducati for swingarm length, shock mounting position etc and transfered these dimensions over to my KZ build. So theoreticaly it should have VERY similar geometry to the Ducati....at least that was the plan. The ZR arm is 1.75" lomger, so I moved the shock mounting point back 1" to compensate for the extra leverage. Obviously the CG etc between the two bikes is quite diferent so other than that its trial and error lol.
The shock spring is for a 200lb rider, I happen to be 200lbs so that worked out well. The bike will likely be 30lbs or so heavier than the Ducati though, so may have to get a different rate spring. Once I weigh it I'll have a better idea.
Its setup with 24.5* of rake as well, so quite steep, but I have a damper to go on so if its twitchy I'll dial in more dampening.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
  • M357.5
27 Feb 2012 15:18
#506661
Started to fab the top brace, I've got a bit more done now, but no pics yet, I'll be tinkering again this evening so I'll post up where I get to later :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Feb 2012 15:40 - 28 Feb 2012 19:25
#506664
i'm lovin it. B)
a KZ caries the weight ratio, back a bit, compared to the duc, so your spring rate should be pretty good.
dont worry about the rake mine is similar and its steady at 125mph.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Feb 2012 19:25 by mark1122.
  • M357.5
28 Feb 2012 18:31
#506880
Here are a few more pic's of the swingarm build.
Putting some heat into the aluminum to weld :)
The upright brace, clamp the hell outta it as aluminum tweaks a bit when cooling as I found out the hard way.
A few of the welds, not use to the spool gun, but other than the stops/starts its not too bad.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
29 Feb 2012 10:48
#506981
them spool gun welds look real nice.i have one but have never personaly used it.now that i know you can get welds that nice it kinda makes me want to try it out. :cheer:
your making some good progress.that swingarm is going to be stout as fU(#. :evil:
keep up the good work and keep us posted,
  • M357.5
29 Feb 2012 10:54
#506982
The spool gun is a bit finiky, I tried using the recomended setting on a few test pieces, and it was so far off its not even funny. I played with the heat/speed for 4-5 test welds and got it working very well. I had guys telling me you cant make nice welds with a spool gun and I was wasting my time.
I must say I'm pleasantly suprised by it, much cheaper alternative to buying a TIG....although a TIG is on my list :)
The brace is HUGE, more I look at it the more its overkill, it's got an in your face robustness lmao. I have a few more plans for using the spool gun, headlight brackets, gauge mount, exhaust mount etc.
  • 531blackbanshee
  • Vendor
  • Vendor
29 Feb 2012 11:22
#506988
on the upside you can polish the piss outta it without worry of getting it too thin :whistle: .
  • M357.5
29 Feb 2012 14:52 - 29 Feb 2012 14:55
#507018
Arrrrgggghhhhh, the swingarm was too big to get any heat into it, just disipated heat way too fast to make it worth while. So a bunch of the welds look like complete ASS. Started grinding them down, and I like it better with the welds smoothed out lol, so not as big of an issue as I had thought.
I clamped the arm to my bench with 6 c-clamps and 3 pair of grips. Tacked everything and started welding, alternating sides/ends to keep it from warping. Let it all cool for 2 hours, cold to the touch, and unclamped it. Set it in the frame and the pivot bolt slid in like butter....so far so good....grabbed the wheel and spacers, set it in, took a DEEP breath and prayed that the arm hadnt tweaked and that the axle would go in as smooth as the pivot.
WELL WHOLY HELL, fookin thing slid in like it was a greased VAG lol, no fightin at all and everything looks spot on. Whhheeeeeeewww glad I didnt fook up the arm :)
Going to do the finishing fab on the mount tonight, so i'll post up what I've fooked up then
Last edit: 29 Feb 2012 14:55 by M357.5.
  • 531blackbanshee
  • Vendor
  • Vendor
29 Feb 2012 19:13
#507059
glad it worked so well for you.
  • M357.5
29 Feb 2012 22:11
#507108
No more wooden box holdin her up, its on her wheels :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
02 Mar 2012 08:18
#507343
SWEET!!!! B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
