Tale of an SR650.
  • M357.5
  • M357.5's Avatar Topic Author
  • Kwakas N' lots of em'
Re: Tale of an SR650.
21 Feb 2012 17:42 - 21 Feb 2012 17:46
#505511
Made some threaded bungs for the rearsets and then drilled the frame, stuck them in and welded em in.
The shock/sub mount 80% finished.
Dzus Fastener plates to mount the fiberglass tail. I cut the seat portion of the tail off, its now about as big as a stock KZ750L tail. The battery tray is an old finned aluminum oil pan off an unknown Honda model.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 21 Feb 2012 17:46 by M357.5.
  • M357.5
21 Feb 2012 17:51 - 21 Feb 2012 17:57
#505514
Still a LONG way to go. I'm working on the seat pan now, working on the mounting points and cleaning up the sharp edges so the cover wont rip. Then high Density foam, shape it with an electric knife and a DA sander. Going to mimick a Corbin/Sargeant style seat.
Then I get to start on the swingarm, install the engine, carbs, exhaust, electrics, lighting, gauges, paint.....should be done in oh a year or two lol.
Guess I should change the name of the thread, nothin left of the 650 I started with is the Engine lol.
Last edit: 21 Feb 2012 17:57 by M357.5.
  • jeffasaki
  • jeffasaki's Avatar
21 Feb 2012 19:09
#505529
Very nice :)
Dont know how I missed this but im glad i found it
keep up the outstanding work
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • Mine20
  • Mine20's Avatar
  • Metric Maniac
21 Feb 2012 23:46
#505581
great work man, I am following this till the bitter end.
2007 Honda Shadow Custom
1978 Kawasaki kz650c2 cafe project
1979 Kawasaki 650sr possible bobber project
  • M357.5
22 Feb 2012 12:12
#505647
Thanks for the kind words guy's its been a slow build...mainly due to my motorcycle ADD that has me changing up the build regularly lol.
Heading out to do some more work on her :) I'll post up later today.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
22 Feb 2012 12:50
#505658
I love that u used an old oil pan to tidy things up under the tail. Great idea.
B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • M357.5
23 Feb 2012 13:38
#505907
Got the seat mounted, used Dzus fasteners for it as well. Picked up some 3M spray adhesive, grabbed the electric knife from the kitchen and have the foam ready. Going to start putting the foam on today and get shaping it.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Feb 2012 13:45
#505910
well dang,
for someone that took this long to get here you sure haven't been wasting time the last few days :woohoo: .
you go boy!!!!!!!!
  • M357.5
23 Feb 2012 13:52
#505913
Ya its been hectic, and I have been working on my other KZ750 too...new tires, wheel bearings, rebuilt/painted the forks, rebuilt/painted the calipers and brackets, have a 4-1 to go on it too....getting it ready for the relay ride :)
  • 531blackbanshee
  • Vendor
  • Vendor
23 Feb 2012 13:54
#505914
good job man knock out everything you can while you got a head of steam built up :evil: .
  • M357.5
25 Feb 2012 13:51
#506272
Used 1" thick high density foam, it was adhesive backed but I've had it forever and the adhesive dried out and didnt stick. Used 3M super77 spray adhesive to glue the foam down to the seat pan.
Borrowed my mothierinlaws electric knife to trim the foam ( dont think she knew what I was using it for lol ) and hand sanded the foam to shape with 180 grit sand paper. I was going to cover it myself, but I'm going to hand over the seat to a local guy that does a real nice job on seats. Covering it with the material Corbin usese, with GREEN piping etc.
  • M357.5
25 Feb 2012 13:56
#506274
Started mocking up the swingarm top brace/shock mount. Using aluminum plate to fab the rear sections and boxing them in, hole saw a few holes in it and insert aluminum tube to weld in...make them look a bit lighter I think. the spars are 1x2 aluminum rectangular tube. The forward section will be a combo of rec tube and plate. And the shock mount will be billet if I can get my friend to make one up on his mill for me.
This is just a quick mock up. The spars will not extend as far forward as this, going to cut/notch/bend them around to create the radius I need = ton of pissin around. But hopefully will look ok when done.
