z1 streetfighter
- kzstreetfighter71
- Atlantic West Coast
Re: z1 streetfighter
18 Mar 2010 20:45
- kzstreetfighter71
18 Mar 2010 20:50
and the front end on to, i did the whole replacing the headstock pin with the z1's that so many have done before. im going with dirtbike bars cause they look so good.
- kzstreetfighter71
18 Mar 2010 21:10
- porchev914
18 Mar 2010 22:10
I'm curious what forks you used, how long they are and how much it dropped your front end. Your build is comming along nicely
FRANKEN Z!
- larrycavan
- StreetfighterKz
19 Mar 2010 04:53
Looks pretty good so far. Just one question, what thickness is the bar stock used in the bracing of the backbone?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- kzstreetfighter71
19 Mar 2010 06:32
yes larry the forks are in total around 3' shorter than stock with the wheel on and yes there is a dip in the front but a low front and a highish rear is the way a classic streetfighter should look, well in my eyes anyways i suppose?
and doug the bar stock i used was 1" by 1/5" i cut each section and the put an angle on to insure a snug fit as with all the tube stock and square bar i used was knotched to make everything hug nice before welding, and as i had to knotch everything with a grinder it was a long job :S.
- StreetfighterKz
19 Mar 2010 07:28
OK, I just didn't want it to be too thin and then flex on you. Thin stuff is fine in tension but sucks in compression.
As far as notching with a grinder, that how I did all my bracing on my 900. I've added 11 braces to my frame; all notched by a bench grinder. Grind, test fit, grind some more, test fit again, etc.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- porchev914
19 Mar 2010 07:42
Thanks for the info, I wonder if by any chance you know the distance between the floor and the bottom of your lower frame tubes? Is your valve cover painted, powdercoated or anodized? What are you planning to do next?
FRANKEN Z!
- kzstreetfighter71
19 Mar 2010 08:08
StreetfighterKz wrote:
i hear ya doug, im goin to invest in a knotcher for my 750 twin project co cut that procedure in half.
Later, Doug
- StreetfighterKz
19 Mar 2010 08:12 - 19 Mar 2010 08:13
kzstreetfighter71 wrote:
I have a knotcher, but I didn't find the right diameter hole saw due to the fact that the tubing is metric and the holes saws are imperial. You can get something close but you'll probably still have to do some fitting with the grinder.
I didn't realize it until I checked just now and you can get metric hole saws through McMaster-Carr for a reasonable $$. D'OH!!
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 19 Mar 2010 08:13 by StreetfighterKz.
- kzstreetfighter71
19 Mar 2010 08:13
porchev914 wrote:
the valve cover is painted with dupicolour hi temp red then a quick coat of metalic red but it doesnt discolour as i did the same with it last time and it lasted 2000 miles no prob, ill measure the ground clearance tonight when i get home for you no prob.
