z1 streetfighter
  • kzstreetfighter71
  • kzstreetfighter71's Avatar Topic Author
  • Atlantic West Coast
Re: z1 streetfighter
07 Apr 2010 18:14
#359094
mark1122 wrote:
Do u have any advice for mounting a tab on the frame to receive the out board plate?
I was thinking about drilling a hole and putting a bolt through with a (BIG)nut on the back side, then tacking the nut to the frame, remove plate and then finish weld. i would think i should have the nut just off the frame , then build up weld to the nut. this might allow for a bit of miss alignment if i dont get the hole in the perfect spot. i would not like to have to elongate the hole to accommodate the nut being slightly off.
is there any way i can use my grinder for this task?:silly:
ha, funny i was going to mount a back plate this weekend but i pre thought of all this a welded a bar to support the battery box and the plate. if your going to drill hole i would go with welding in a sleve instead like the way i did here for my rear sets.
  • kzstreetfighter71
07 Apr 2010 18:16
#359095
ha, funny i was going to mount a back plate this weekend but i pre thought of all this a welded a bar to support the battery box and the plate. if your going to drill hole i would go with welding in a sleeve instead like the way i did here for my rear sets.
its a long winded way but it wont compromise your frame and as walltoall said safty first!!;)
  • kzstreetfighter71
07 Apr 2010 18:19
#359097
like this.
  • porchev914
  • porchev914's Avatar
07 Apr 2010 19:49
#359134
KZ71 is right Mark, you'll want to put sleeves in the drilled holes. If you don't, you will most likely crush the frame tube when you tighen the bolt down :S And after all the work you have already put into that frame, you don't want to damage it ;)
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 Apr 2010 17:32
#359336
What i meant was to weld the nut on the side of the frame tube.
I just dug out the plate and placed it on the bike for the first time.I should have done this before i asked. i was at work at the time.
Ben actually has it pre-drilled, and provided a bolt and a threaded sleeve for the back. so i will do as i suggested, but rather than welding a nut to the side of the frame rail, i can weld the supplied sleeve. i'm sure the sleeve will look more "PRO" than a nut welded on there.
Maybe i can use my grinder to clean up the weld.:laugh:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
08 Apr 2010 21:31
#359400
I was wondering what you might be refering to Mark. I'm still gonna see if I can even use the frame mounts. If I do, I may have to modify my frame a bit. I'm not sure I'm ready to start cutting my frame up just to mount a bearing support...... :laugh: :laugh:
FRANKEN Z!
  • kzstreetfighter71
09 Apr 2010 06:29
#359442
there you go problem solved! but i use a 60 grit sanding disk on my grinder for cleaning welds, less chance of nicking metal or goin to deep, canadian tire do "use once" ones which are real good.
  • testarossa
  • testarossa's Avatar
09 Apr 2010 07:38
#359452
Mark carries his grinder in a holster like John Wayne would a peacemaker!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • kzstreetfighter71
09 Apr 2010 11:23
#359510
my weapon of choice is a deWalt reciprolcal saw, chop chop chop.:laugh:
  • porchev914
09 Apr 2010 13:05
#359525
Yeah, but are you man enough to trim your fingernails with it like Mark and his grinder :laugh: :laugh:
FRANKEN Z!
  • kzstreetfighter71
09 Apr 2010 19:13
#359599
hahaha no but my saw would make short work out of a family pizza.ha.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
10 Apr 2010 04:30 - 22 May 2010 05:14
#359646
You really have to try a cut off disc for that. You would be amazed. it remelts the cheese at the cut. This works as a lubricant on the disc.
It's Amazing, i tell u, and it's easier on the box too.:P
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 May 2010 05:14 by mark1122.
