OMR: '76 KZ900 Restoration/Modification
  • Motor Head
  • Motor Head's Avatar
Re: OMR: '76 KZ900 Restoration/Modification
07 Dec 2011 22:34
#492108
Sure Larry, It was one of those early morning deliveries at a Country store. The Tanker Driver put the wrong fuel into the underground holding tank at the Pumps. They are a Gas stop on a Country road on the way into town for a lot of people. So along with gas, people get coffee, return videos, etc.
Welcome back to the Forum!
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
07 Dec 2011 22:49 - 13 Feb 2012 17:41
#492111
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:41 by KZ250LTD.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
08 Dec 2011 01:35
#492134
Old Man Rock wrote: Here's the basics of the wiring harness I will be fabbing up....
Subject to change on the left hand control for turn signal and horn but close enough to get started.
NOTE: Note sure if I will be going with the Oil pressure gauge as depicted...
Very nice! How do you make such a nice wiring diagram? I would love to make one for my custom wiring job (already done), just to have as a reference for the future (getting older and tend to forget things LOL)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • LarryC
  • LarryC's Avatar
08 Dec 2011 09:06
#492157
Motor Head wrote: Sure Larry, It was one of those early morning deliveries at a Country store. The Tanker Driver put the wrong fuel into the underground holding tank at the Pumps. They are a Gas stop on a Country road on the way into town for a lot of people. So along with gas, people get coffee, return videos, etc.
Thank You!
What I was specifically wondering about was if the delivery drivers had something to do with the alcohol mix content or something like that.
A few years back I ran into a problem with a detonated piston. It happened 15 miles after I filled up at a Valero Station.
Larry C.
  • LarryC
  • LarryC's Avatar
08 Dec 2011 09:14
#492159
I see no real value in an oil pressure gauge on a roller bearing KZ Dave. Just something to stick out of the end of the motor and get snapped off from a simple tip over [God forbid that happen but we're human and shit happens].
Value would be an EGT gauage......
JMO
Larry C
Larry C.
  • Motor Head
08 Dec 2011 09:44
#492164
For an EGT you need a probe in each pipe, close to the port. Cylinder Head Temp might be another good Idea. There are a lot of great gauges out there these days that will sound warnings, record data, and you can set the range of Temp for the Warning to occur. I think it can be linked to the Ignition as well. The Head Temp Gauges we used in the past had a ring that went in under the Spark Plug, so no need for a sending unit hole tapped in somewhere.
  • LarryC
  • LarryC's Avatar
08 Dec 2011 16:59
#492213
Motor Head wrote: For an EGT you need a probe in each pipe, close to the port. Cylinder Head Temp might be another good Idea. There are a lot of great gauges out there these days that will sound warnings, record data, and you can set the range of Temp for the Warning to occur. I think it can be linked to the Ignition as well. The Head Temp Gauges we used in the past had a ring that went in under the Spark Plug, so no need for a sending unit hole tapped in somewhere.
That's what we always ran on our sleds.
Larry C.
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
08 Dec 2011 19:52
#492234
"How do you make such a nice wiring diagram?".... Windows, MSPaint
As mentioned, I'm not sold on the oil pressure gauge as well... Rather have a AC amp meter. ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • clutch
  • clutch's Avatar
08 Dec 2011 20:21
#492235
Old Man Rock wrote: "How do you make such a nice wiring diagram?".... Windows, MSPaint
Ok...I just stink at making wiring diagrams then. Must take practice. LOL
Wish List:
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
08 Dec 2011 20:33
#492237
I think I owe you an apology, I just went thru this build for the first time, ever. It was before I had started posting much on here. My point? A man looks at a beautiful bike and it warms his heart, looks at the build details of the same bike while under construction and it warms his soul! You sir have a beautiful bike.
Sorry to hear of the health problems your close family member had. I myself would have to lean towards clips coming out of groove. The wrist pin appears to be hanging out to the right in the pic. I have seen them come out before, I'm sold on buttons even for a simple performance build.
Best luck getting it straightened out.
Les Holt
08 Dec 2011 20:39 - 08 Dec 2011 20:41
#492238
Kudos to OMR for vast improvements after his earlier works. :cheer:
Last edit: 08 Dec 2011 20:41 by Patton.
08 Dec 2011 21:13
#492247
Patton wrote: Kudos to OMR for vast improvements after his earlier works. :cheer:
I may be wrong, but doesn't that center picture show the coil mod? :whistle:
