Long time rider. First KZ750
- Jsolonka89
23 May 2016 17:06Attachment 13269444_1687279631537079_230197362_n(1).jpg not found
This is my 1983 KZ750. I picked it up on Saturday for 900 smackers.
Needs a little attention but not much.
She runs great.
Few things I plan on doing.
1.Clean the carbs.
2.New spark plugs
3.Oil change. *if anyone has any information about a filter that would be fantastic*
4. Figure out why the hell my gas tank meter doesn't function
5.Tires are good enough to ride my .5 miles to work.
6. Mirrors.
If anyone has anything to add. Feel free to let me know. I am open to suggestions.
I almost want to cut the rear fender bars off and move the tail light up under the seat.
Re: Long time rider. First KZ750
23 May 2016 17:10
No eBay APP ID and/or Cert ID defined in Kunena configurationThis might work.
- Tirefire Pat
- (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
23 May 2016 17:12
Welcome to your new addiction..lol..beautiful Bike and congrats on the steel,,you stole the ride my friend..stay safe...pat
23 May 2016 17:18
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
23 May 2016 17:35
- Jsolonka89
23 May 2016 17:59
Thats what I keep hearing. People can't believe the guy let me have it for 900. Hell after doing more research I cant believe it either.
- Jsolonka89
23 May 2016 18:01 - 23 May 2016 18:03Jsolonka89 wrote: Where would one acquire such a tool?
Sears (assuming you are in the USA)
BTW, a regular #3 bit fits fine in the Kawasaki case screws.
Last edit: 23 May 2016 18:03 by Nessism.
23 May 2016 18:02
Or, AZ Pep Boys, etc. Be sure you get the 3/8" drive so you can use sockets too.
- GPzMOD750
23 May 2016 18:04 - 23 May 2016 18:12
Nice KZ750L that is a very nice bike for the price. They are becoming nearly if not as rare as the 82 GPz750.
That tank is hard to find. Please don't hack it up. If you wan't to modify it let me know I'll trade you mine that has some dents in it. The fuel gauge sender unit may be faulty and need replacement but it could just be a short in the connectors or wiring like mine has but I haven't had a chance to correct. When it starts acting up I just reach down and jiggle the connectors.
Various parts for that bike interchange with the 1982 (only) GPz750 (aka KZ750R1), the KZ700A, the KZ750E and the GT750 (aka KZ750P, very rare in the states).
The ZR7 (ZR750) from 99-05 is basically updated version of the KZ750 series and many of the parts will work with various degrees of modification including engine swaps. Some Parts from the ZRX1100/1200 series will work with little trouble as well. If you want a factory speedo that goes up to 150mph, if yours if form the 85 only era, you can find them in the UK that fit many models just drop the "k" out of the model designation to find one. i.e. Z750L.
This is my 82 GPz that I'm in the middle of resto-modding, taking extreme care not to do anything irreversible. The shocks are ZRX and many of the other non standard parts are from or intended to go on a ZR7.
Last edit: 23 May 2016 18:12 by GPzMOD750.
- GPzMOD750
23 May 2016 18:10 - 23 May 2016 18:10
I'm using an infiltro filter.and I know emgo has one as well. I bought a Fram first but was warned very strongly not to use it as they are known to disintegrate.
Last edit: 23 May 2016 18:10 by GPzMOD750.
23 May 2016 18:27
Most online motorcycle parts places also sell K&N oil filters that fit your bike. Ed
