Advanced Search
Search Results (Searched for: gs swing arm)
Replied by FJR1 on topic Z400 Custom G3 1981 project
25 Nov 2018 11:26 - 25 Nov 2018 11:28
FJR1's Avatar FJR1
Hello Everyone!!! Here is the Sunday Update!!!
Not much progress this week. I sand blasted the tank, found more rusted area, the plan now is to look for a good looking petrol cap and fit it before I close the tank.
I reshaped the metal where the dents were, I would need some filter to make it smooth.
I am very busy this next week, so I will just try to removed the rest of the rust and spray an anti rust inside the tank. Than If I have time I will start to fibre glass it.
I manage to cut the frame and test some shapes for the seat, but I am not liking. I two days ago, bough a swingarm from a Ninja Ex250 2010 which should arrive on Thursday or Friday, from my research is a direct fit. The advantage is that It has mountings for the caliper which would hopefully ease the conversion.
After fitting the swingarm, I will decide whether to modify the subframe to make the seat thinner, and push the shock mounting forward. But it still need to be decided. Here are the picture of the work done this week.
Thank you!!!
engine swap question was created by KZNEPA
23 Nov 2018 04:52
KZNEPA's Avatar KZNEPA
thank god I found you guys.. Happy Thanksgiving ..
So I bought a 1983 Kz750 twin ltd belt drive for $300 in pretty good shape typical "hasnt ran in ten years" .. What I thought was just a stuck piston ended up being a seized lower end...
So I got back on the marketplace and found a basketcase of a 1987 Kz750 twin with a good motor but frame is all chopped up and the wiring is a mess... but its chain drive (woohoo) its got the spoked wheels (woohoo) and a set of gold mags with disc brakes and caliper... all for $200 with no title..
so I started the swap last night and quickly found out the belt drive swing arm is almost an inch wider then the chain drive swing arm.. you cant just swap swing arms because the shocks on the LTD are actually sitting wider on the frame. So i think im going to just keep the wider swing arm and try and make a spacer for the axle bolt..
well that was the first hurtle .. looking at the motors all the mounting locations are the same.. so that doesnt seem to be a problem but the wiring is a little different. the plugs arent the same..
would it be easier to swap wiring harnesses then try and make the 83 harness work on the 87?
i tried finding wiring diagrams for both with no luck, also tried searching the forums for other people that may have ran into a similar situation .
thanks guys
also will be parting out a lot of this stuff when im finished
Replied by martin_csr on topic First time vintage bike owner
20 Nov 2018 20:25 - 21 Nov 2018 09:42
martin_csr's Avatar martin_csr
Rear wheel. The KZ1000P also has an 18" rear wheel, but it's wider than the 750E. The 1000 probably uses a bigger axle (larger diameter), so the other hub stuff is bigger as well. The wider wheel may not be a problem, since your swing arm already accepts a wide Ltd. I believe the 750H is 3" wide, the 750E is 2.15" & the 1000P is 2.50". I don't know if there will be brake rotor alignment issues with a Police wheel. There may be wheel bearings that will mate a 1000 wheel to the 750 axle. I don't know if a larger axle can be used with the 750 Ltd swing arm.
You can compare stuff at Partzilla. There are other places w parts diagrams, such as Kawasaki.com or cmsnl.com, but partzilla is the easiest to use.
Replied by z1kzonly on topic The Sights And Aroma Of Your Motorcycle Workshop!!!!
18 Nov 2018 18:44
z1kzonly's Avatar z1kzonly
I'm all about the mess too! Too small of a garage! ( I know where it all is at!! ) No space or money to build or rent. I'm stuck. Me too, I'm old and worn out!
But this is my sanity. I have ADD - ADH or whatever? I seem to start stuff and never finish! Got 10 projects going?
Whatever? Loud Blues music, bright lights and a 100,000 BTU oil furnace in a small garage. Plenty warm in the cold!
I'm smelling lacquer fumes today stripping a GS1100 aluminum swingarm? (heat only runs 2-3 times) no thinner out when that is on.
2 sets of HD FLH tanks to paint. Cut up a small KZ front fender, shortened it! Unique, will fit Z1-KZ900-1000. I might even use it myself.
Have a real clean KZ900 front set of forks to finish. Just got the AllBall seal & wiper set. Waiting on a friend to surface grind 2 - KZ 4 hole discs to finish.
Beer and opiods help. Hey edible states! NY sucks. I'll send you my address! :P :woohoo:
Replied by Dr. Gamma on topic Better Than Nothing---The rebirth of a Superbike.
14 Nov 2018 15:24
Dr. Gamma's Avatar Dr. Gamma
I got to ask Mr. Muzzy questions about the S1 for about 40 minutes or so. The factory S1's were a lot different than the S1's that Kawasaki sold to the normal folks. The standard S1 came with cams marked as "47" and "48" He asked what number cams that were in my S1. When I told him #47 and #48. He looked a bit puzzled, and said they were running #52 and #53 numbered cams!!!! He did tell me that he was running the early style KZ1000 outer clutch basket with the needle bearing instead of the bushing style that came in the J model motors. The S1 front forks were plain junk and needed LOTS of work and different parts to make them right. Again, some of the parts were specially supplied by Kawasaki race shop in Japan. Which I could not get or buy.
Everybody ran a pretty wide handlebars on their Superbikes. From the big boys down to the privateers ran like the K&N Superbike bars. Spencer used to bend his bars sometimes during a race!!!! You wanted all the leverage you could get in case your bike went into a high speed wobble. Even when Kawasaki ran the GPz750's in '83, they mounted handlebars to the bikes instead of the clip on style bars the bikes came with.
I used either Yoshimura 1015cc slipper pistons or Moriwaki 1105cc pistons and never had a piston to valve clearance problem unless I missed a few gears!!!! Then I would tag an exhaust valve or two.
The stock S1 only made like 110~115 horsepower out of the box. And that was after you dialed the carbs in. Plus the swing arm pivot bolt had like .060 ths play between the frame and the pivot bolt stock. And like I said, the front forks were a joke, they had like .004~006 clearance between the inner and outer legs. It wobbled like an old H2 triple when I first put it on a race track. I did a roll on from 2nd gear between my home made Superbike and the fancy S1. Even giving the S1 the jump my home made Superbike would run it down by the end of 3rd gear!!!! I was expecting a lot more from the S1 than what I got from it.
77 kz1k restomod was created by jowek70
12 Nov 2018 15:17
jowek70's Avatar jowek70
Been floating around the boards a bit and figured it’d be fun to share progress on a 1977 kawasaki kz1000.
The story goes somewhat like this...
Dad bought this from an estate sale a few years ago and my brothers and I ended up tearing it apart to rebuild with some of the spares we had laying around the barn.
Engine went out to the builder shortly after and a few minor parts came in the mail in the mean time. Got it to a rolling chassis then it sat and started collecting dust.
3 years later my dad talked me into taking it home. So I broke down what we had and packed it into my hatchback. Started measuring tings up, making parts list and dropping parts off to various places.
I figured I will have it mostly together by this spring but the goal is to have this ready to give back to dear old Dad in June 2020 for his 60th birthday.
Pics so far...
Attachment not found
So far I am nearing completion on the front end. Using a 94-96 zx9 forks/wheels/brakes/clip-ones with stock gauges/bracket. Luckily the kz speedo runs off the speedo sensor from the zx9.
Using the stock gas tank, side panels, rear fender with zx9 front fender painted to match. Gas tank needs restored inside though unfortunately but the other panels look great. My dads a big fan of chrome so I polished up the chrome and have been adding chrome nuts and bolts throughout to keep that look.
Well be using the gs1100 swingarm with dual shocks and a modified rear brake system. This will use the stock brake pedal set up with modern rear master and custom pieces to go from master to pedal. Rear caliper will be from zx10 using zx9 rear caliper mount and custom wheel spacers and 520 chain to fit the 180 wide rear tire.
The goal is to have a retro bike with great power, reliability and updated brakes/tires/suspension.
Replied by Move0ver on topic CR29 jetting and decel backfire
10 Nov 2018 10:57
Move0ver's Avatar Move0ver
A little bit of thread necromancy, but I've got some relevant updates for running CR29s on the (at least my ) Z1.
I've had the bike on the dyno a few times in the past week, dialing in my AFRs.
After the first run I saw that idle was super lean and then went off the charts rich just after throttle. AFR got better at 3/4 to WOT.
That told me two things, that I needed larger idle jets (what kerker/SUDCO call slow jets) and a larger diameter (leaner) needle.
Run 1 was with 52 slow, 112 main, YY8 needle 3 clips from the top.
Run 2 was with 55 slow, 112 main, YY9 needle 3 clips from the top.
On run 2, the idle was still lean, but not as bad as before.
I'm going to probably jump up to size 60 slow jets (which is what the carbs normally come with when you buy them new). That combined with the air screw adjustments should fix the leanness at idle.
Run 2 with the new needle showed marked improvement in the AFR at 1/4 to 3/4 throttle. We went from an AFR of 9ish/1 to around 11.2/1 (with the end goal of being 13.1fuel/1air).
***The snag is that with the aftermarket rim and larger tire, combined with the box swingarm I have about 1/2" of clearance. At high RPMs, the tire expands enough to rub on the swingarm cross brace (in the video you can see a puff of black)
I'm going to fix the clearance when I upgrade the rear to disc brake and then we'll do Run 3 in the spring.
Run three will probably be the following: 60 slow, 112 main, YY9 needle 2 clips from the top.
Here's the HP chart and AFR chart from the dynojet:
70hp at around 8k RPM... that's with significant rubbing of the rear tire, so hopefully it's a little more after I fix it.
Here's a quick video of one of the intermediary runs (not the spray of rubber near the end of the pull)
Finally, pictures of the rubbing and existing clearance:
Hopefully this information is helpful. I'll update it again in the spring once I get back on the dyno.
Tapered roller steering head bearings was created by Marky2
09 Nov 2018 21:13
Marky2's Avatar Marky2
The bike is a 1980 Z1r D3 that is undergoing a complete restoration. The frame has been sand blasted and painted and new swingarm bearings installed. I have just completed the installation of tapered roller steering head bearings but have discovered two issues. The first is that the steering stem head nut only needs hand tightening before the steering gets tight. My workshop manual doesn't have a torque setting for this nut but to me it doesn't seem tight enough when the steering stem can be moved easily from side to side without binding. The other issue is that after installation of the top triple clamp, when I measure the distance between both triple clamps and then compare the measurement to that of the fork cover that sits between the top and bottom triple clamp there is about a 6mm difference - ie. the gap between the triple clamps is 6mm longer than the length of the fork cover. I'm not sure if this is correct, but again, it doesn't seem right. It looks as though the top triple clamp is not sitting low enough because the steering stem head nut is not going on far enough.
I have measured the bearings as best I can and they look to be correct (although measuring the thickness of bottom one is a bit hard due to the proximity of the grease seal) . Both top and bottom races were pressed in using threaded rod and appropriate sized washers and are seated correctly. In another post, someone experienced a similar issue on a 1975 Z1 (I think) and they ended up machining a few mil off the steering stem nut to fix it but I don't have that sort of equipment.
Has anyone experienced similar issues and is there a suitable fix? Thanks.
Replied by Daftrusty on topic kz750e Resto-Mod
21 Oct 2018 13:58
Daftrusty's Avatar Daftrusty
scubaanders wrote: Rusty!
The ZR750 rim is 110 mm across.
/A
Thank you!! I really appreciate you doing that for me. I measured my spare zr550 front wheel and it is 100mm, so I will have 5mm on each side to deal with. So I will need to research brake disks that don’t have so much offset.
I test fit the Bassani exhaust on the bike and the gs1100 rear section wasn’t all that far off. But there is only 2mm between the muffler and my swingarm and I don’t like how straight back it goes. So I had to cut the mid-pipe to space it out from the swingarm and give it some upsweep.
So this is my current mock-up after two days of continuous measuring, thinking, cutting and fitting.
Before:
After:
Replied by waktaylor on topic Wakt out KZ1000
14 Oct 2018 11:40
waktaylor's Avatar waktaylor
Removed the bent garbage fork today. Also went a little nuts with the cut off wheel. modified rear fender. removed passenger pegs. Bandit swing arm hits them.
More pics to come this afternoon.
[img
[img
Displaying 641 - 650 out of 7255 results.
