Advanced Search
Search Results (Searched for: gs swing arm)
1980 KZ440A LTD Bobber Project was created by SilentNoise
25 Apr 2012 01:23 - 25 Apr 2012 01:24
SilentNoise's Avatar SilentNoise
Hey, I'm Steve. I just picked up my first bike a week ago (80 KZ440A LTD) to take on as a bobber project - something I've wanted to do for ages now, but being in Canada, a car is a bit of a priority since there's snow on the ground for 5-6 months out fo the year.
I bought the bike last week from a guy who was building it in the garage of his girlfriend's house, but due to a breakup, he was forced to sell. The bike was in overall good shape and ran pretty well when he started the project. Before winter hit he was able to get the back end stance sitting about right, picked up a Sportster-style tank and was getting ready to weld up the swing arm for a budget hardtail conversion.
Anyway, here's my progress on the project up to this point. If you're on Facebook, hit the link in my sig for more pics.
When he bought it last year
Attachment 01_2012-04-25.jpg not found
Chopped rear end with Harley springs, Sportster tank and front fender in place to get an idea
Attachment 07_2012-04-25.jpg not found
Mon, April 16: Delivered to my garage
Attachment 2012-04-1621.32.03.jpg not found
Tues, April 17: Electrical and handlebars stripped. Straight bar set in place... I'm still trying to figure out what bars I want to use, but this does look good and beefy.
Attachment 2012-04-1723.22.45.jpg not found
Tues, April 17: How he left the back end. He had the flatbars in place in preparation for frame mods to weld up the swingarm... I'm toying with a real hardtail conversion with the universail kit from TC Bros. (need to talk to my uncle who's a tradesman welder and see if he'll be willing to work for beer... he just retired this winter, so hopefully he needs a weekend project ;))
Attachment 2012-04-1800.19.13.jpg not found
Wed, April 18: Engine out. That wall-mounted folding bench I made last fall is damn handy for the project.
Attachment 2012-04-1823.08.48.jpg not found
Thurs, April 19: De-greasing and cleanup central
Attachment 2012-04-1901.04.51.jpg not found
Fri, April 20: My regular work bench is relocated for a great bike lift. I started to knock off tabs for the plastics, reflectors, etc. over the weekend, but I need to borrow the old man's air compressor because my little 3 gallon tank doesn't have the balls to run my mini die grinder for more than 10 seconds at a time, making cleanup ridiculously slow and just painful.
Attachment 2012-04-2022.04.28.jpg not found
Replied by baldy110 on topic KZ650 Bolt-On Swingarm Upgrade?
24 Apr 2012 11:45
baldy110's Avatar baldy110
There is no real "bolt on" swingarm. The closest would be the GS1100 at least with this one there is no fitting required just a few small washers.
Replied by KZJOE900 on topic 1976 KZ900 back on the road.
24 Apr 2012 10:12
KZJOE900's Avatar KZJOE900
Thanks for all the suggestions guys. I haven't had a chance to look at the problems in detail. Only got to move the bike a few feet and inspect the chain. The good news is, all the noise was coming from the chain, none from the wheel bearings. The bad news is the chain is shot and so is my bran new 275 mile rear sprocket. Not horrible news, cause it was the chain that came from the barn and only had two notches of adjustment left. Yes, should have replaced it without even thinking, but didn't want to plow more money in a bike I had only rode for 1/2 a mile. As I had mentioned, I had replaced the rear sprocket. In stalled it, lubed the chain and started riding. Now the new sprocket is toast after only about 275+ miles or so. Had it adjusted to 3/4" slack now its at about 2" or more. That was part of the symptom taking off from first gear. What could cause a chain to stretch so fast. Anyhow, I'm taking the sledge hammer approach this time. This should take into account everybody's suggestions and I had intentions of replacing these parts anyways but the relay deadline got in the way. Don't want to go back in to fix twice. So I decided to do a 530 chain conversion and ordered the following:
1. front sprocket.
2. rear sprocket.
3. spacers for conversion and chain link.
4. RK 530 110 link x ring chain.
5. front wheel bearings.
6. rear wheel bearings.
7. valve cover gasket (hopefully tapping noise will be resolved with adjustemnet)
8. valve shim tool.
I have to decide this morning on whether to purchase the swing arm bushings and sleeves. They also sell a kit (pricey) that has pin bearings instead. Anybody have any opinions on these? JD, Marc, Ramtough, Ed and everyone else, thanks for the help.
Replied by smilesuper on topic kz1000 parts plus vfr swingarm plus gsxr front end
23 Apr 2012 00:09 - 23 Apr 2012 11:58
smilesuper's Avatar smilesuper
Attachment kawsssa.jpg not found
frame is from 1993 kz1000 police ,wheels are from kz1000 police too , wider rear rim, both are straight
parts are from one of my 1982 kz1000j and 1993 kz1000 police and also gpz1100 , and a ltd
I am getting rid of my kz parts because of selling my bike
www.use.com/editset.pl?set=7192f2052d1f27932233
i have one set of carbs from kz1000j , stand, battery holder, front rear calipers, kz1000j ignition cover w housing , center stand, clutch cover, sprocket cover, more and more also kz450 650 750 turn signals,kz650 kz1000j manifolds, kz needles
please check links what i have . Are you ready for 190 55 tire ( the rim can handle ) , OR you can even replace honda civic rear rim on that arm, same spacing . it is up yo you can put wider and wider tires ,depends on your NEW rim choose.
Note : you can enlarge every single picture for more details
www.use.com/editset.pl?set=e9ab53bbe83353c67327
www.use.com/editset.pl?set=ca15e574370635277ec4
www.use.com/editset.pl?set=1ab37a1170340dc8b5ff
www.use.com/editset.pl?set=a999a7a3d807be12f4a0
www.use.com/editset.pl?set=ae2a49e8d0f66fb2e1c5
www.use.com/editset.pl?set=3d84ca78e9e33d142f3e
contact me w the same title'''''kz1000 parts plus vfr swingarm and gsxr front'''
yzg72 a t y a h o o
thank you
KZ650 Bolt-On Swingarm Upgrade? was created by seanof30306
22 Apr 2012 21:27
seanof30306's Avatar seanof30306
OK, I've done a lot of searching on this, but I don't see anything definitive.
First, I love the look of the factory Enkei 7 spoke wheels, so I'd want to go with a Kz1000P rear wheel (like Mark Wing did).
Second, I want to stay with a dual-shock setup, as I really like that look.
I've seen where people have done the Zephyr swingarm upgrade, although I'm unclear as to whether the 550 or the 750 is preferred, and I've found a lot of old posts both here and on kz650.info about the GS1100 swingarm, but it's not discussed much anymore. Is there a reason it's fallen out of favor?
Are there other options?
Which choice is best?
Thanks
kz1000 parts plus vfr swingarm plus gsxr front end was created by smilesuper
22 Apr 2012 18:35 - 23 Apr 2012 13:51
it has clean clear CA title , never been in any accident , i do have auto check record, not carfax. auto check is more detailed...interested ones contact me w title kz1000 frame , i also have complete rear and front wheel for sale, i do have more parts belonged to kz1000 , including carbs, and more yzg72 at yahoo thank you
pictures will be added later ,thank you
Replied by mark1122 on topic 1976 KZ900 back on the road.
22 Apr 2012 08:40 - 22 Apr 2012 08:49
mark1122's Avatar mark1122
Glad to here u r up and running.
Congrats. :)
the 15 wieght oil will not cause this, but not enough oil , or un-equal amounts, could. did u have to push the springs down a bit to get the bolts into the fork tops? just wondering if there is any play in the springs?
def check the rim runout. Swingarm bushings too.also check the tire psi.
where do u think this squeal is? if its the wheel bearing, that may have something to do with the wobble.
Replied by 650ed on topic Diagnosing handling problems. Solution
21 Apr 2012 19:21
650ed's Avatar 650ed
Another way to ensure the steering stem bearings are properly tightened is to use a modified spanner and torque wrench (folks know I’m a big believer in torque wrenches). I attached my spanner to a metal bar and then cut a 3/8ā€ square hole in the bar centered 7ā€ from the centerline of the spanner lug. I can now attach this to my torque wrench. Keeping the spanner bar in the same line as the torque wrench, I can now adjust the torque of the steering stem bearings to the spec recommended in the service manual. Of course, you absolutely must take into account the extra leverage that results from the 7ā€ spanner bar length or you will greatly over-tighten the bearings. Fortunately, the formula and instructions for calculating the correct, adjusted torque setting is clearly described on the CDI (Snap-On) website. If anyone has an interest in more details, just ask. I used the modified tool below when I installed my tapered roller bearings and it worked like a charm. The forks have zero excess play but still will swing lock to lock with no binding. Ed
Attachment spanneradapt.JPG not found
Attachment Spannerandwrench.jpg not found
Attachment TorqueTable.jpg not found
Replied by Kawickrice on topic What is a 1980 Z1R 1000 worth?
19 Apr 2012 22:46
Kawickrice's Avatar Kawickrice
Flyndrive wrote: So are all those things really good like the rake and swingarm? Or is there so much that is not original it takes a lot of worth away?
So if I got it running would it be worth much more? Is it worth fixing up to sell?
If it is raked the value will decrease as far as being original. Frame mods are hard to reverse if looking for a true original. On the other hand it may be worth it for someone looking to run a drag bike. Look it over good it very well could have been a drag bike one time ago. Could be someone made a bad ass street motor and added some goodies, the reflector is still on the frame so it probably was not a track only bike. Either way tell him about the flaws and talk him down as was mentioned earlier. I would love to run across one for the right price. $500 to $750 not running. It will be interesting to see what he thinks it is worth.
It will be worth more running than not, so if you can get it cheap not running and get it running you could possibly make some money if it is just carbs and gas tank gummed up from sitting.. If the motor is blown then it will be a money pit as far as selling for a profit.
Replied by Flyndrive on topic What is a 1980 Z1R 1000 worth?
19 Apr 2012 22:19
Flyndrive's Avatar Flyndrive
Displaying 2851 - 2860 out of 7236 results.
