kz1000 parts plus vfr swingarm plus gsxr front end
- smilesuper
22 Apr 2012 18:35 - 23 Apr 2012 13:51
it has clean clear CA title , never been in any accident , i do have auto check record, not carfax. auto check is more detailed...interested ones contact me w title kz1000 frame , i also have complete rear and front wheel for sale, i do have more parts belonged to kz1000 , including carbs, and more yzg72 at yahoo thank you
pictures will be added later ,thank you
Last edit: 23 Apr 2012 13:51 by smilesuper.
- DiamondSkyBlue1000
Re: kz1000 frame, wheels , calipers , more for sale
22 Apr 2012 23:23
What year? Is it a standard or an LTD? Please provide photos and/or more details.
Thanks.
Thanks.
- smilesuper
22 Apr 2012 23:50
frame is from 1993 kz1000 police ,wheels are from kz1000 police too , wider rear rim, both are straight
i have one set of carbs from kz1000j , stand, battery holder, front rear calipers, kz1000j ignition cover w housing , center stand, clutch cover, sprocket cover, more and more
also kz450 650 750 turn signals
- smilesuper
22 Apr 2012 23:56
- smilesuper
Re: kz1000 plus vfr swing arm plus gsxr front end
23 Apr 2012 00:09 - 23 Apr 2012 11:58Attachment kawsssa.jpg not found
parts are from one of my 1982 kz1000j and 1993 kz1000 police and also gpz1100 , and a ltd
I am getting rid of my kz parts because of selling my bike
www.use.com/editset.pl?set=7192f2052d1f27932233
i have one set of carbs from kz1000j , stand, battery holder, front rear calipers, kz1000j ignition cover w housing , center stand, clutch cover, sprocket cover, more and more also kz450 650 750 turn signals,kz650 kz1000j manifolds, kz needles
please check links what i have . Are you ready for 190 55 tire ( the rim can handle ) , OR you can even replace honda civic rear rim on that arm, same spacing . it is up yo you can put wider and wider tires ,depends on your NEW rim choose.
Note : you can enlarge every single picture for more details
www.use.com/editset.pl?set=e9ab53bbe83353c67327
www.use.com/editset.pl?set=ca15e574370635277ec4
www.use.com/editset.pl?set=1ab37a1170340dc8b5ff
www.use.com/editset.pl?set=a999a7a3d807be12f4a0
www.use.com/editset.pl?set=ae2a49e8d0f66fb2e1c5
www.use.com/editset.pl?set=3d84ca78e9e33d142f3e
contact me w the same title'''''kz1000 parts plus vfr swingarm and gsxr front'''
yzg72 a t y a h o o
thank you
Last edit: 23 Apr 2012 11:58 by smilesuper.
