KZ650 Bolt-On Swingarm Upgrade?
- seanof30306
22 Apr 2012 21:27
OK, I've done a lot of searching on this, but I don't see anything definitive.
First, I love the look of the factory Enkei 7 spoke wheels, so I'd want to go with a Kz1000P rear wheel (like Mark Wing did).
Second, I want to stay with a dual-shock setup, as I really like that look.
I've seen where people have done the Zephyr swingarm upgrade, although I'm unclear as to whether the 550 or the 750 is preferred, and I've found a lot of old posts both here and on kz650.info about the GS1100 swingarm, but it's not discussed much anymore. Is there a reason it's fallen out of favor?
Are there other options?
Which choice is best?
Thanks
Thanks
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- baldy110
Re: KZ650 Bolt-On Swingarm Upgrade?
24 Apr 2012 11:45
There is no real "bolt on" swingarm. The closest would be the GS1100 at least with this one there is no fitting required just a few small washers.
