Advanced Search
Search Results (Searched for: gs swing arm)
Replied by wireman on topic Swingarms...
24 Mar 2013 18:00
wireman's Avatar wireman
90s gsxr 650-1000 are same width at pivot as the 81-82 gs1100e,needs roughly 1/8" of shims on each side of pivot tube.
Attachment leehlahslash_001-94c065bf314a5f3981b140ec7c953be1_2013-03-24.jpg not found
The length you make it depends on how big of a turbo youre running and just how bad you want to hold it down! :woohoo:
Mental note to self 3" over just aint enough when the 1327 spools up the ol T3/4 garret! :sick: :woohoo:
Replied by wireman on topic Is this GSXR Swingarm/Wheel going to work?
24 Mar 2013 17:20
You can run a 520/525 sprocket with 530 chain,just need to center chain up on sprocket is all.
Make sure you buy a new rear sprocket to go with the chain :)
Is this GSXR Swingarm/Wheel going to work? was created by badrhino
24 Mar 2013 16:41
badrhino's Avatar badrhino
I am planning on running a 06-09 GSXR 600/750 rear swinger/wheel combo on my 1980 KZ1000 sometime down the road. I am buying all of the parts so I have them here. I just purchased the rear wheel and it comes with the rotor/sprocket. I noticed that these are running 525 pitch sprocket and I just converted my KZ to the 530 chain and sprockets. I really don't want to have to convert to the 525 (if even possible) to run this set up. Does anyone know if you can get 530 pirch rear sprockets for the newer (06-09) Gsxr 600/750's??? :pinch:
Swingarms... was created by racer54
23 Mar 2013 18:03 - 23 Mar 2013 18:05
racer54's Avatar racer54
This might be a good one to keep in the archives if there is enough response but what I would like to know is how long different swingarms being used are and how wide that swingarms front pivot tube is. Been looking at Busa and GSXR-1000 arms...stock and extended that will work on our KZ frames and it makes it difficult not knowing how long different arms are in stock form. I know a stock KZ arm is 19 1/2" long from center of front pivot bolt to center of axle slot. How long and how wide is the front pivot tube on a hayabusa? GSXR-1000? GSXR-600/750? ZX12R? or any other bike. If anyone who has replaced their swingarm with one off another bike would list these specs for the front pivot tube and stock length, maybe we can get some kind of file going so anyone can just look and see which one will fit their build ideas. I know I'm looking for a l-o-n-g version. I've tried asking sellers and most times just get...3" longer then stock! Don't really help. Most aftermarket builders who still build for our KZ's won't build a street arm longer then 6". They tell you to buy a clubfoot which won't work with shocks unless you heavily modify them which defeats the purpose. Anyone have these measurements they can post?
Replied by donthaveakawman on topic High speed wobble.
23 Mar 2013 02:48
donthaveakawman's Avatar donthaveakawman
you might check the swing arm bearings. even when my axle lines up on the notches it still doesn't seem straight. and I have a wobble also.
Replied by Haybus on topic KZ 900 new school old school Project
20 Mar 2013 21:50
Haybus's Avatar Haybus
Looks cool. 6" is a lot to add to a swingarm that wasn't all that stout to begin with. Have you considered adding some bracing? How about extending the inner flange of the extension further into the original legs? Doesn't look like a lot of engagement in the pic.
Replied by w8lifter21 on topic 5/8 offset sprocket measure question
20 Mar 2013 17:31 - 20 Mar 2013 17:33
w8lifter21's Avatar w8lifter21
So I shouldn't worry by putting an '04 GSXR rear swingarm/wheel and using it as a commuter bike should I? Now you guys have me paranoid about bearing failure LOL
Replied by Woody73 on topic Swing arm mod, old to new idea for feedback
20 Mar 2013 04:21
Woody73's Avatar Woody73
LeePalmer79 wrote:
Attachment 2013-03-02_14-56-23_499.jpg not found
this is my starting point picked it up fot $400.. i have the 01-03 GSXR swing arm and shock ready to go in and am looking for the best way to do the upper shock mount..
once you figure it out, post up some good pics & a thread on it. this was what i was thinking for mine as well but without being able to see my bike in person right now, i kinda stumped on how to fab up the shock mount.
Replied by LeePalmer79 on topic Swing arm mod, old to new idea for feedback
18 Mar 2013 17:38
LeePalmer79's Avatar LeePalmer79
Replied by Voxa_33 on topic 81 651 Fighter project
17 Mar 2013 14:56
Voxa_33's Avatar Voxa_33
Hi!
I'm working on similar bike 650 with GSXR front and ZR-6 wheels and swing arm. Wot you thinking to weld for rear shocks? I going to have two and riserching wot would be the best!
www.kzrider.com/forum/11-projects/571936...1-kz-650-ltd-project
Thank you
Displaying 2401 - 2410 out of 7260 results.
