Is this GSXR Swingarm/Wheel going to work?
  • badrhino
  • badrhino's Avatar Topic Author
24 Mar 2013 16:41
#578554
I am planning on running a 06-09 GSXR 600/750 rear swinger/wheel combo on my 1980 KZ1000 sometime down the road. I am buying all of the parts so I have them here. I just purchased the rear wheel and it comes with the rotor/sprocket. I noticed that these are running 525 pitch sprocket and I just converted my KZ to the 530 chain and sprockets. I really don't want to have to convert to the 525 (if even possible) to run this set up. Does anyone know if you can get 530 pirch rear sprockets for the newer (06-09) Gsxr 600/750's??? :pinch:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • wireman
  • wireman's Avatar
Re: Is this GSXR Swingarm/Wheel going to work?
24 Mar 2013 17:20
#578565
You can run a 520/525 sprocket with 530 chain,just need to center chain up on sprocket is all.
Make sure you buy a new rear sprocket to go with the chain :)
  • Haybus
  • Haybus's Avatar
  • Big Al
24 Mar 2013 18:12
#578583
Z1 Enterprises has a bunch of 530 sprockets. Not sure they have that one, though they might be able to get it for you. Worth a call. Here's your sprocket dimensions.
www.jtsprockets.com/catalogue/model/1733
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • badrhino
24 Mar 2013 19:39
#578603
Wireman that's why I was hoping they made 530 pitch for the GSXR wheel. I already have a new 530 chain and sprockets for the original setup. Just hoping all I would need to do is get a 530 rear sprocket for the new (gsxr) wheel. I have done a little research and found nothing so far.
So are you saying I could use a 530 chain with 530 front sprocket and a 525 rear?!
Franken Z!
  • wireman
  • wireman's Avatar
24 Mar 2013 19:42
#578604
Yes,just make sure to use a new sprocket so you don't tear up your new chain B)
  • badrhino
25 Mar 2013 01:46
#578679
Franken Z!
  • Hollywoodmx
  • Hollywoodmx's Avatar
25 Mar 2013 10:48
#578693
badrhino wrote: I am planning on running a 06-09 GSXR 600/750 rear swinger/wheel combo on my 1980 KZ1000 sometime down the road. I am buying all of the parts so I have them here. I just purchased the rear wheel and it comes with the rotor/sprocket. I noticed that these are running 525 pitch sprocket and I just converted my KZ to the 530 chain and sprockets. I really don't want to have to convert to the 525 (if even possible) to run this set up. Does anyone know if you can get 530 pirch rear sprockets for the newer (06-09) Gsxr 600/750's??? :pinch:
A 20 second search on ebay and it was full of 530 rear sprockets for gsxr. :whistle:
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • badrhino
25 Mar 2013 20:29
#578749
Not for the 06-09 GSXR 600-750 there isn't. :whistle:
Franken Z!
  • Hollywoodmx
25 Mar 2013 23:02
#578782
Take this;
www.jtsprockets.com/catalogue/model/5832
And search for the same dimensions on another bike on the website but for 530.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • badrhino
26 Mar 2013 01:21
#578808
Thanks, yeah I did stumble across that site.
Franken Z!
  • badrhino
30 Mar 2013 16:57
#579628
I got the rear rim in the mail today off a 09 GSXR 600-750. Came with the sprocket/brake hub/axle and as a bonus a like new Battlax 016 tire. :lol:
Franken Z!
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
30 Mar 2013 17:17
#579632
If you cant find a sprocket you could always get a custom one made.
1977 KZ 1000 work in progress
