Is this GSXR Swingarm/Wheel going to work?
  • z1wiz
  • z1wiz's Avatar
Re: Is this GSXR Swingarm/Wheel going to work?
30 Mar 2013 23:53
#579731
call 800-782-8200 or www.sprocketspecialists.com/
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
  • Hollywoodmx
  • Hollywoodmx's Avatar
31 Mar 2013 12:35
#579797
badrhino wrote: Thanks, yeah I did stumble across that site.
Just yesterday I was looking for an 18t from sprocket for my tr-1 and low an behold a xs650 heritage special had the same dimensions, couldn't find anything. Did not find it on any forum or anything just used the JT specs to find it.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • badrhino
  • badrhino's Avatar Topic Author
01 Apr 2013 01:24
#579884
I hope the rear wheel I got is going to work it is a 6 inch rim with a 190 tire on it. I thought I read somewhere that this rim may be too wide. :(
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
01 Apr 2013 13:39
#579951
it will take an offset countershaft sprocket to get passed the wheel.
maybe have to clearance the frame as well.
  • dsmking
  • dsmking's Avatar
04 Apr 2013 00:03
#580476
Some one put the wrong tire on the 09 rim, should be running a 180, if yore geting an 06-09 swing arm the tire /rim will fit, un less you bought a rear rim off a 1k rear rim, if that's the case you will need a 1k swing arm the 1k rim is to wide for an 600-750 swing arm. If you're interested in a swing arm off an 07 gsxr 750 shoot me a PM
live fast die young.
  • badrhino
06 Apr 2013 02:59
#580797
Actually it is the older straight spoke rim from around 06-08 and it must be off of the 1000 since it is a 6 incher. The guy sent me the wrong wheel. He had a picture of an 09 listed. Oh well I got it for $125 plus it has a like new Bridgestone 190 on it.
Franken Z!
  • dsmking
  • dsmking's Avatar
06 Apr 2013 20:50
#580931
Nice , yea you will need a 1k swing arm but you probably knew that lol
