Search Results (Searched for: gs swing arm)
Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
Replied by RedBullEnema on topic GS1100 swingarm (eye to eye conversion)
15 Apr 2013 17:27
To tell you the truth, I think it would be much easier (and possibly safer) to lop off the current brackets on the swinger and find a good aluminum welder in your area to set you up for an eye mount.
I would look much cleaner and OEM to boot.
Im currently staring at my GS1100 swinger in the garage wondering if I should do that before mounting it up, it would give a whole lot more options for suspension.
GS1100 swingarm (eye to eye conversion) was created by K.D. HART
13 Apr 2013 12:29 - 13 Apr 2013 12:43
I've been stumped on how to run piggyback shocks on my Z1 with a GS1100 swingarm without spending a ton of $$$$$$$.
I want to do something like this bike.
I have a idea of a set of machined shackles that would fix this problem. I made a simple drawing of my idea as it came to me.
(The "orange" part in the drawing is thicker and contoured to the eye on the swingarm).
The two pieces come together and sandwich the factory GS1100 swingarm eye.
This is with the back piece of the shackle in place.
Can anyone here make these?
swingarm exchange was created by deezy
13 Apr 2013 01:31
Got a ??? curious, i just recently bought my first bike.. 77 KZ650. Great bike, but i wanna swap out the swingarm.. to add a lil length & wider tire in the rear... a friend of mine gave me a swingarm off a 01' or newer gsxr 1000.. i know the older gsxr swingarm will fit wit a lil modifaction. but was wondering if anyone had some info??? I would greatly apperciate the help....
Replied by K.D. HART on topic gs1100 swingarm Q's
13 Apr 2013 00:38What shocks are those and does anyone know of a gas charged shocks that won't break the bank?
I have gs1100 shocks on my mockup but they are too short. Eye to clevis is 13.5
It's just going to be too low. I want to install, maybe a set of 70's LTD wheels and front forks.
Trying to make a low budget version of this bike.
www.ac-sanctuary.co.jp/rcm-list/gallery/z1_z2/rcm121/index.html
I think I might use Les's rearsets, but can't find eye to clevis shocks like I want longer than 13.5??? Anyone have ideas????
compare.ebay.com/like/400385277818?var=l...ceItemTypes&var=sbar
What is the eye to clevis measurement on goldwings?
Thanks
Replied by stevie g on topic more swingarm stuff
12 Apr 2013 06:36
I cannot post pics, don't know how to but here is the ebay number if you want to look at it. GSX1100F Swingarm. 310527861225 Also one of the guys on here said that kawasaki zx6 are pretty close and are about 3 inches over the Z so that is what I would be looking for preferably. $tevie.
11 Apr 2013 13:09
I'm finding a lot of GSX1100 F swingarms on the UK ebay site and they are 230mm at the pivot and 650mm overall length. Would that be the same as a GS1100 ?? I'm not sure if the UK models are called different to the USA models, same as we have Z over here, you have KZ
gsxr full suspension swap on 76 kz900 was created by high toned son of a bitch
11 Apr 2013 09:47
Hey guys, here's what I have done so far.
76 KZ900
2003 gsxr 750 rear swingarm/wheel/shock/etc
2003 gsxr 750 front suspension/triple tree/tire/etc
My problem is the forks hit the tank when I turn like in parking lot manuvers. This is with the stock tank. I have an old tank from my 79 1000 Shaft Drive, and it is better, but the tank doesn't really fit the frame very well. I can make it work, but I am running out of time to get this baby fixed up. WHat tank do you guys use? It's like my triple tree needs to angle/push the forks forward more.
The only other issue I have is the clip on's from the GSXR are REALLY far forward. I have to lean forward AND my elbows are locked. It's not terrible, but not the most comfortable either. I would like something where I don't have to lean forward quite as much. So that means the handlebars/clip-on's I'm looking for need to come up and back a little.
Thanks for any help guys!!!
MIke
76 KZ900
MIke
Replied by gumby prichard on topic Kz750 Twin Cafe (yep another)
11 Apr 2013 02:44
also if you look closely you can see i used the reverse peg method to compatible with the kz750 to create rear set pegs. Here she is at barber.
welp back from barber and it's time for teardown and complete customization.
adding mags and dual disk from a kz750ltd/kz700
had to shave down the width of the swingarm of the kz750ltd about 1-2mm on each side to fit.
fitting the TM38's to this baby:))) many modifications will be going into these carbs due to the fact that they are specifically built for a different vehicle.
almost forgot after barber i immediately developed a mold i was satisfied with for my rear faring. ZX6 influenced.
Attachment image-2.jpeg not found
Attachment 295141_399160306832183_435670800_n.jpg not found
Attachment image-3.jpeg not found
Attachment image-1.jpeg not found
Attachment image-7.png not found
Attachment image-6.png not found
Attachment image-4.png not found
Attachment image-5.png not found
racer54 wrote: For all you guys who have done this...when you decide to go mono-shock, how do you decide where to put the top shock mount? I have seen where the shock if fairly straight up with a mount right is the middle of area under seat to where the mount is on a crossmember welded in between framerails running down behind engine. Does it really matter the angle of the shock? How did you determine the height of the top mount? I am assuming this is a way to adjust the ride height while building your bike. Mount the shock higher in the frame to lower the ride height or does the bottom mount determine this to some extent? What linkage is best to use? Do you just find the cheapest setup you can and build around it or what? I know some buy a whole bike and take pieces from it but what if you can't find a whole bike to rob from and have to buy piece by piece...are the parts able to mix and match...say a zx12 swingarm using a gsxr1000 linkage? Been looking around E-Bay and its hard to find a complete front end with brakes, wheels, forks etc. as well as finding a complete rear setup with swingarm. wheel, brakes, linkage, etc. to use on a build. As you can tell, I'm lost on this so any information and insight you want to share would be great.
Sorry about the multiple posts...this site is giving me lots of problems logging on, cutting me off and now this...
You should be able to get all the parts from one model....maybe not one bike but at least all the same model. Avoid mixing things if at all possible.
I got forks and wheels with brakes from a guy in Canada, swing arm and shock off ebay. The worst part was bidding on f'n foot pegs. You would not believe what a pain in the ass that was :laugh:
Look at how the shock mounts on the model you get that stuff from. You'll see if there's angle to it or relatively straight. This may help. It's from when I was doing my LTD 1979 LTD Streetfighter
Displaying 2341 - 2350 out of 7260 results.
