Kz750 Twin Cafe (yep another)
- gumby prichard
11 Apr 2013 02:31 - 11 Apr 2013 02:57
So I am starting this thread way late. I decided to post it here because this is where my kz journey began, with my kz400. You guys(especially Patton and Bounty Hunter) helped me so much with my 400 and with this bike. So enjoy and please ask any questions!
This bike was started about a year ago. I have everything to put it back together just waiting on money to powdercoat the frame.
This is what it looked like when i got it fresh from a backyard mechanic shop who pretty much wired it with chicken wire and couldn't figure out the issue....
BE SURE TO FOLLOW @NORICUSTOMS ON INSTAGRAM OR FACEBOOK FOR MORE ON THIS BUILD AND OTHERS TOO!
bought some zx6 clip-ons and had some spacers milled. Also chopped the rear.
i temporarily just took the stock rear faring and mounted it to the rear so i could ride it at barber, just wasn't satisfied though, too generic.
[attachment:7]photo.JPG[/attachment]
Attachment 424602_238707249544157_618716625_n.jpg not found
Attachment image-3.png not found
Attachment image.png not found
Attachment image-2.png not found
Attachment image-1.png not found
Attachment photo.JPG not found
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 11 Apr 2013 02:57 by gumby prichard.
- gumby prichard
Re: Kz750 Twin Cafe (yep another)
11 Apr 2013 02:44
also if you look closely you can see i used the reverse peg method to compatible with the kz750 to create rear set pegs. Here she is at barber.
welp back from barber and it's time for teardown and complete customization.
adding mags and dual disk from a kz750ltd/kz700
had to shave down the width of the swingarm of the kz750ltd about 1-2mm on each side to fit.
fitting the TM38's to this baby:))) many modifications will be going into these carbs due to the fact that they are specifically built for a different vehicle.
almost forgot after barber i immediately developed a mold i was satisfied with for my rear faring. ZX6 influenced.
Attachment image-2.jpeg not found
Attachment 295141_399160306832183_435670800_n.jpg not found
Attachment image-3.jpeg not found
Attachment image-1.jpeg not found
Attachment image-7.png not found
Attachment image-6.png not found
Attachment image-4.png not found
Attachment image-5.png not found
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
11 Apr 2013 02:51 - 11 Apr 2013 03:04
Also upgraded to a dyna electronic ignition for a 750 4 and just took one of the pickups off. works great!!! Upgraded to some vintage progressive shocks i found. Repainted the springs. Has zx6 controls and front brake master cylinder. I will post more pictures of all my powder coated parts once i am ready for reassembly. I will also pose the Paint and fiberglass process soon.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 11 Apr 2013 03:04 by gumby prichard.
- baldy110
- Larson
- boatdrinks
11 Apr 2013 15:28
Nice project. You mentioned that you rode it to Barber. Are you in Alabama? I'm up in the Huntsville area.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
- gumby prichard
12 Apr 2013 01:20 - 12 Apr 2013 01:22
Im in knoxville! Tn. Hopefully i'll be racing vintage mx next year with either my Rt360 or my F9/F8 350. Don't know if i'll bring this bike. may not have any room. All depends if i have my mx bikes finished in time.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 12 Apr 2013 01:22 by gumby prichard.
- boatdrinks
12 Apr 2013 07:50
I grew up in Knoxville. Do you ever make it over the the Time Warp Cafe? A local vintage bike club calls that their home.
Charles
Madison, AL
Madison, AL
- BCbikes
12 Apr 2013 07:57
are those the stock forks and upper crown? I am looking to change my kz550 upper crown to something flat so I can use clip-ons
1980 kz550a
- gumby prichard
14 Apr 2013 03:38
Boat drinks, yep sure do. I got every Tuesday now. Took me a good ten times over the past year to finally become a member to timewarp mc. Memeber 191. You should come down for one of the rides!.
Bcbikes, yes they are stock triple tree clamps and forks. The bottom clamp actually has a chrome protective shield over it stock. So with it the triple clamp is just black, but yes front end is all stock.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
19 Dec 2015 22:45 - 19 Dec 2015 23:16
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 19 Dec 2015 23:16 by gumby prichard. Reason: Delete
- gumby prichard
19 Dec 2015 22:59 - 19 Dec 2015 23:14
Wow time flies. So I needed to refernce setting my timing on my ignition for on the 750 twin and decided to log in and continue this thread.
As for my excuse, the 750 twin was running and ran but never fully finished aesthetically and legally...twilight was never mounted. In the meantime I got very into vintage motocross and bought a kx400 and a 80' klx250 along with a few other dirt bikes I now longer own. I've recently decided to get back into finishing this project (it's about time) and want to continue documenting it. I plan to get a go pro soon and document all the procedures o am unable to find instructional videos on. Anyway here's a few things I've done to the bike in the past 3 years.
-dyna s ignition(half 750-4) ignition
-zx6 electrical controls, master cylinder and throttle, cables, and clip ons
-custom milled shims for clip-ons
-shortened frame
-kz650 rear faring
-kz700/kz750 hybrid front end (kz700 bottom end forks,kz750 twin top end forks)
Kz700 dual disc calipers, updated kz700 rear caliper w/ modern rear nissin master cylinder.
-flipped kz750 pegs w/ zx shifter linkage
-shortened and rewelded brake pedal.
-aluminum foot pegs
-powdercoated various parts and frame (so I bought my own Powdercoat and took it somewhere. I realized when I picked up the frame that the powder I bought was actually a textured (stone) powder where as I thought it was a metallic charcoal, so jokes on me. I plan to tear it all down once a its done and sand blast and repaint.)
-kz700 mags
-kz650 rear swingarm(had to grind down the inside of the frame about 1mm on each side
Everything I've done to this bike is been mostly off top. I kept the kz upper fork legs to keep it low. The kz700 legs are longer but they are pressurized, personally I don't think air shocks are necessary for a street bike, at least for my purpose. I'm not racing this bike however I do plan to do some performance upgrades.
I have a paint scheme that I designed I plan to implement, the main things I'm missing are the lithium batter and battery box I have yet to fabricate. I also have a another surprise as far as cosmetics.
I am currently working on mounting the tail light and glassing the seat pan. Very excited about this bike being finished. I also plan to have a starter hole plug milled unless anyone knows someone who sells them? If you guys have any questions just let me know! Thanks guys
-shortened frame
-kz650 rear faring
-aluminum foot pegs
-kz700 mags
Attachment image-6.jpg not found
Attachment image-7.jpg not found
Attachment image-8.jpg not found
Attachment image-9.jpg not found
Attachment image-10.jpg not found
Attachment image-11.jpg not found
Attachment image-12.jpg not found
Attachment image-13.jpg not found
Attachment image-14.jpg not found
Attachment image-15.jpg not found
Attachment image-17.jpg not found
Attachment image-5.jpg not found
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 19 Dec 2015 23:14 by gumby prichard. Reason: Organization
