Advanced Search
Search Results (Searched for: gs swing arm)
Replied by SWest on topic How to check swing arm bearings?
18 Mar 2016 07:04
SWest's Avatar SWest
:( bummer
Replied by RonKZ650 on topic How to check swing arm bearings?
18 Mar 2016 06:54
RonKZ650's Avatar RonKZ650
You guys are all talking of other motorcycles which use either a sleeve and bushings or a sleeve with little needle bearings. Yes these need lube quite often, and even then aren't heavy duty. The shaft used real roller bearings. Not to say they don't need lube, but chances of them being in bad shape is definitely less than on other Kawasakis.
They built everything on the shaft heavy to last, then in 1981 went to the KZ1100 shaft and all heavy duty was replaced with regular duty parts.
18 Mar 2016 06:34
Isn't it lubricated internally? My grease zerk was backwards so I couldn't get to it. Got another one that would face the right way, by that time the damage was done.
Replied by car5car on topic How to check swing arm bearings?
18 Mar 2016 06:23
car5car's Avatar car5car
Do I have to remove drive shaft to grease left bearing? (shaft model)
Replied by GKBO on topic How to check swing arm bearings?
18 Mar 2016 03:33 - 18 Mar 2016 15:37
GKBO's Avatar GKBO
Dealing with the aftermath of what happens when the swing arm bearings aren't greased. on my 82 GPz750.Those nice heavy duty roller bearing can be turned into so much rust.Got to replace the sleeve,bearings and the pivot bolt because it was so stuck it had to be pounded out.Unlike your KZ1000 most of those parts are NLA from Kawi :S Swing arm and shocks have they're own fiche on the ones I've looked at.Yes I'm going to ad a grease nipple to the swing arm.
Replied by davido on topic How to check swing arm bearings?
18 Mar 2016 00:24
davido's Avatar davido
If I remember right,back in the day,Kawasaki swingarms had a reputation for drying out bearings.So much so that people would drill a hole under the pivot area and thread in a grease nipple.
Maybe an urban legend but twas one of those things,like Yamahas were known for seizing brake calipers and Suzukis for bad electrics and Hondas for dodgy camchain tensioners.
Replied by larriken on topic Kiwi GPZ
18 Mar 2016 00:13
larriken's Avatar larriken
Now that the swing arm is mounted properly it means I can move onto the rear rim. First order of business is sorting out the smaller diameter axle vs the larger axle diameter of CB1300. Easiest and safest way to get over this issue is to fit try and find bearings with the same outside dimensions but an internal that fits the ZZR axle diameter. Off to Saeco bearings tomorrow to see what I can find...............Will keep you posted.
17 Mar 2016 19:52
True. B)
Replied by PLUMMEN on topic How to check swing arm bearings?
17 Mar 2016 19:48
PLUMMEN's Avatar PLUMMEN
RonKZ650 wrote: They used two heavy duty, good quality roller bearings. Like all the KZ1000E parts, basically the best of the best quality and heavy duty, made to last. I wouldn't worry about the bearings unless you're up in the 200,000 mile area. Age doesn't matter to a bearing.
It matters if theyve never been greased! :laugh:
17 Mar 2016 19:27
Greas them.
Displaying 1121 - 1130 out of 7257 results.
