whats the best extended swingarm budget build
- 79kzkaw1000
23 Feb 2016 08:31
79 kz 1000 im looking for some help on a cheaper extended swingarm any help would be appreciated
Re: whats the best extended swingarm budget build
23 Feb 2016 09:04
No eBay APP ID and/or Cert ID defined in Kunena configurationI've had my eye on this one for a long time. Supposed to bolt right up. I suggested it to another member. Good thing I'm making my own.
kzrider.com/forum/5-chassis/600555-swing...zzr1200?limitstart=0
The following user(s) said Thank You: PLUMMEN
23 Feb 2016 09:33
Why extend the swing arm? Do you want the bike to handle poorly? If so, maybe you can adapt a version of the extended swingarm shown below.
Attachment long-2-3.jpg not found
23 Feb 2016 10:28
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationMine will be 1 1/2 longer. Better high speed stability and keeping the tight turning radius. There IS a limit to everything.
Also was watching these.
Still am. I'f mine were made of steel, it would be on the bike now. Just waiting on Jeff when he has the time. :whistle:
- zukdave
23 Feb 2016 16:35
If you think 1 1/2" will not affect the handling you are wrong.
I ran mine at 1 1/2" over and could tell a diff.
I'm now 8" over and it handle's like shit anywhere but the drag strip.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: 650ed, Nessism
23 Feb 2016 16:41
I guess I'll find out. It's supposed to do away with the tank slappers. Not much more than that.
23 Feb 2016 19:30 - 23 Feb 2016 19:30
If you're having tank slappers there' something wrong with the bike. Could be tires (that happened to me), swing arm bushings/bearings; steering stem bearings; shocks; forks; etc. Ed
Last edit: 23 Feb 2016 19:30 by 650ed.
23 Feb 2016 19:33
Z1's are notorious for that.
23 Feb 2016 19:53
That being the case, would a steering damper help? Ed
23 Feb 2016 20:24
That's what frame gusseting and reinforced swing arms are for. I've always wanted a dampener too.
24 Feb 2016 08:4579kzkaw1000 wrote: 79 kz 1000 im looking for some help on a cheaper extended swingarm any help would be appreciated
how much over are you wanting to go???
how wide of rear tire are you wanting to run???
are you wanting to swap wheels ???
- KZB2 650
24 Feb 2016 11:18
After break in I really went out and pushed it and got a fairly scary wobble out of it ...... rear tire was worn a little on the flat side and after replacing it it went back to being fine...... when I had plans for a all out street 810 motor I planned on a 4 inch over (and damper) knowing it would handle like a truck but was more interested in a straight line. Might just think about a damper and call it a day now.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
