Triple tree stand
  • Godfrey
  • Godfrey's Avatar Topic Author
Triple tree stand
08 Feb 2016 13:10
#710015
I've seen triple tree stands for sport bikes, and I'm wondering if anyone has been able to use them or something like them for older kz's?
www.amazon.com/Venom-Motorcycle-Triple-H...keywords=triple+tree
1981 650CSR frame
1980 KZ750E engine
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Triple tree stand
08 Feb 2016 13:15
#710017
A small floor jack works for me and has more uses.
  • JR
  • JR's Avatar
08 Feb 2016 14:35
#710025
My inexpensive (cheap) approach to a triple tree stand for my kz750
www.kzrider.com/forum/21-tools/595750-ra...wheel-off-the-ground
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
09 Feb 2016 03:43
#710080
as long as there is a large enough hole in the bottom of the steering stem for the pin to slip into it will work.
  • daveo
  • daveo's Avatar
  • Premium Member
12 Feb 2016 07:33
#710578
Godfrey wrote: I've seen triple tree stands for sport bikes, and I'm wondering if anyone has been able to use them or something like them for older kz's?
I've had great luck with this jig, and had the entire front-end off the bike to change the head bearings. I trust it as long as the bike's center-stand is locked, and the bike is positioned on a level and solid floor surface, and the bike isn't moved around too much while wrenching on it. Best to break-loose the nuts and bolts before jacking it, then final tighten them after the tire is back on the floor.
1982 KZ1100-A2
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
12 Feb 2016 08:26
#710581
Nice stand Daveo ;)
Dave B) B) B)
  • kzz1king
  • kzz1king's Avatar
22 Apr 2016 19:33
#722461
These are all good if you have a centerstand. Any DIY ideas for those of us without?
Wayne
Home built KZ1000 turbo setup
22 Apr 2016 22:33
#722484
For LTD owners, there's always the
Click here > Standard Biker's Pipe
Good Fortune! :)
  • GPzMOD750
  • GPzMOD750's Avatar
22 Apr 2016 22:41
#722486
kzz1king wrote: These are all good if you have a centerstand. Any DIY ideas for those of us without?
Wayne
Get a cheap paddock stand from harbor freight or cycle gear.
  • DoctoRot
  • DoctoRot's Avatar
23 Apr 2016 02:26 - 23 Apr 2016 02:28
#722496
daveo wrote:
damn your bike is clean!
I have a cheap triple stand i got on amazon and have used it on my kz650. its OK, it has a couple different pins so you can use it on a wide range of bikes.
Last edit: 23 Apr 2016 02:28 by DoctoRot.
  • pete greek1
  • pete greek1's Avatar
23 Apr 2016 10:31
#722549
Wayne
you can buy a rusted up center stand for cheap, & only install it when you want to raise the bike, & take it off when you're done, only two nuts & bolts, takes about 2 minutes to put on or take off
Pete
