Kz 750 road racer , dry clutch project 02 Jan 2021 20:18 #841082
  • richard
  • richard's Avatar Topic Author
  • Thank you received: 15
Built this road racer a few years back
As a challenge , it's been competitive
Now I've decided to go down the rabbit hole
And build a dry clutch
Took lots of pics on the build over the last month,not tooting my horn yet because
Only 75% complete,but looks promising
Kz 750 road racer , dry clutch project 02 Jan 2021 20:44 #841085
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
It would be interesting to see how you did that.
For future posts, if you click Insert or Insert All before submitting, the pictures will show up as high resolution pics in the thread instead of tiny little thumbnails.
Kz 750 road racer , dry clutch project 02 Jan 2021 20:44 #841086
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Looks like fun. Are those two different paint jobs, or are the stripes different colors on different sides? Also, what's that gizmo with the tube coming out of it located where the starter motor used to be?
My dad's '74 Z1
'00 ZRX1100
Kz 750 road racer , dry clutch project 02 Jan 2021 21:00 #841088
  • richard
Gizmo is my remote starter
Slide into cog ,hit button using one hand
No kick ,bike starts then remove
That's another project LoL
Kz 750 road racer , dry clutch project 02 Jan 2021 21:09 #841089
  • richard
I will try the insert,I'm better at machining than tech Lol
Basically I used a Ducati monster tried and trued dry clutch and slowly converted to kawasaki
Kz 750 road racer , dry clutch project 02 Jan 2021 21:12 #841090
  • richard
Was originally green
But wanted something a bit more 70s
Kz 750 road racer , dry clutch project 02 Jan 2021 21:23 #841091
  • richard
Started with a 3/4 slab of aluminum and started cutting till I had the main housing
Kz 750 road racer , dry clutch project 03 Jan 2021 10:35 #841120
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Wow impressive machining, and the bike looks great too. any more pics of the bike? what organization are you racing with? keep the pics coming!
Kz 750 road racer , dry clutch project 03 Jan 2021 11:47 #841125
  • Dr. Gamma
  • Dr. Gamma's Avatar
Interesting project!!!! Going to keep an eye on this one for sure!!!
Here is a close up shot of the dry clutch set up on the factory GPz750 Kawasaki that Mr. Muzzy put together back in 1983.
1986 RG500G 2 stroke terror.
Kz 750 road racer , dry clutch project 03 Jan 2021 13:18 #841130
  • richard
With the VRRA in Canada
After plate was fitted up ,the oil level window was machined in
Kz 750 road racer , dry clutch project 03 Jan 2021 13:28 #841131
  • richard
Only pics of the bike
It's covered at the moment
Use to be green and black
Now sporting 70s colours
Kz 750 road racer , dry clutch project 03 Jan 2021 13:46 #841132
  • richard
This shows how the Ducati cast iron cush drive was made into a different design
Using aluminum,the original Kawasaki clutch basket spline was removed from the cast alum basket and pressed into the newly fabricated billet cush drive
