Kz 750 road racer , dry clutch project 03 Jan 2021 14:03 #841133
  • richard
  • richard's Avatar Topic Author
  • Thank you received: 15
The main gear that supports the Ducati basket and main seal was made from 4140 annealled ,it's essentially a Ducati gear with Kawasaki gear pitch cut on to it ,then carburized to 58 rockwell, then machine the seal and bearing after returned from heat treat
Kz 750 road racer , dry clutch project 03 Jan 2021 15:41 #841137
  • JR
  • JR's Avatar
  • Thank you received: 429
Awesome work!!!
Kz 750 road racer , dry clutch project 03 Jan 2021 16:10 #841140
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
richard wrote: Gizmo is my remote starter
I was looking at the piece where the starter motor usually is, with the two AN fittings and hoses coming out of it.
My dad's '74 Z1
'00 ZRX1100
Kz 750 road racer , dry clutch project 03 Jan 2021 16:34 #841142
  • richard
Sorry I read that wrong
It's a catch tank to catch oil vapors from getting on the track
Had a spot where the starter use to be so put it there
Did this one for a Honda CB
Same idea
Kz 750 road racer , dry clutch project 03 Jan 2021 18:44 #841145
  • richard
These pictures show the black steel Ducati
Basket weight,to get the full affect of the dry clutch I went with an after market aluminum basket
Kz 750 road racer , dry clutch project 03 Jan 2021 23:22 #841168
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
its a shame the damper basket is hidden. are you machining this stuff manually? nice work.
Last edit: by DoctoRot.
Kz 750 road racer , dry clutch project 04 Jan 2021 04:53 #841173
  • richard
If you mean the Kawasaki basket damper
It's all gone including the drive gear attached to it,I couldn't find pics on how the Kawasaki guys did it,so figure use Ducati
It's smaller diam,lighter,it's proven and piles of parts,it's a matter of changing things to kawasaki spline and making it all work
The other pics show the cover
It's carved from a 84 gpz750 clutch cover
Yes all done manual from my mill and lathe in my garage
Only thing outsourced was gear cutting and heat treat
Kz 750 road racer , dry clutch project 04 Jan 2021 08:23 #841178
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 265
Absolutely brilliant. Very well done. I'm quite envious.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Kz 750 road racer , dry clutch project 04 Jan 2021 09:14 #841180
  • richard
Not out of the woods yet I haven't
Bolted it to my race bike yet
Black hardware on the left is Ducati
Made the hardware on the right
From 4140 pre heat to fasten Ducati clutch drum to kawi spline
Tiny holes are for lock wire
Large holes for weight
Kz 750 road racer , dry clutch project 04 Jan 2021 10:20 #841183
  • Dr. Gamma
  • Dr. Gamma's Avatar
I LOVE your thinking and the workmanship!!!!! Wish I had your ability. I love the sound of a dry clutch. I have one on my GSXR750 LTD.
Does the Ducati dry clutch have that same great sound??
Are you going to add some type of filler cap so you can add oil in that fancy cover you made up??
Can't wait to see your next post!!!!!!!!
1986 RG500G 2 stroke terror.
Kz 750 road racer , dry clutch project 04 Jan 2021 12:02 #841184
  • richard
Filler cap on its way
Will be tight thought
Know someone local that has a few
Limited Suzukis with the dry clutch
Very cool bike
Top shows how the cush drive works
Bottom 2 pics are the covers being modified
To accept clutch push rod
Unfortunately only had 83 to 85 gpz covers without the hole ,this was faster than searching for the proper one's
Attachment not found
At this point things will slow down a bit until
The bike goes on the lift, unfortunately motor needs to be pulled and split due to the fact the 83 motor had a plug were the rod ran through
Kz 750 road racer , dry clutch project 04 Jan 2021 12:06 #841186
  • richard
