An attempt to paint my GPZ 750 Tank
- HeavenlyMachines
20 May 2017 21:44 - 20 May 2017 21:46
I had a quote to paint it professionally for $500 which is decent and would be a top job. But why not try it first just to have fun
Let the good times roll...
gpzninja.blogspot.com.au
Last edit: 20 May 2017 21:46 by HeavenlyMachines.
- HeavenlyMachines
Re: An attempt to paint my GPZ 750 Tank
20 May 2017 21:47 - 20 May 2017 21:48
Last edit: 20 May 2017 21:48 by HeavenlyMachines.
- HeavenlyMachines
20 May 2017 21:51
Some trial sanding with 350 grit and learning how to do filler
First attempt was a fail as I did not put enough hardener and the filler would not cure. Not fun to having to scrape every gooey thing again
The following user(s) said Thank You: Mcdroid, GPz550D1
- Mcdroid
- Gone Kwackers
21 May 2017 00:21 - 21 May 2017 00:22
We are watching...document all your steps
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 21 May 2017 00:22 by Mcdroid.
- HeavenlyMachines
21 May 2017 01:04
OK sure. here's my learning so far:
1) Read the instruction on the filler/bondo. Too little of hardener and the bloody thing would not cure
when done right, they actually cure *really fast* so after a while I learnt just to mix small amount at a time
2) support the tank fully. I DROPPED IT because it was wobbly on the table. Luckly it landed on the seam and no further damage
21 May 2017 05:01 - 21 May 2017 05:01
Is this going to be a rattle can special paint job or are you using a spray gun and real automotive paint? If you are doing the later then I strongly suggest you stop and fully strip off all the old paint using paint stripper. Starting fresh is always best.
Last edit: 21 May 2017 05:01 by Nessism.
21 May 2017 06:09
Why remove the emblems and fill in the emblem depressions and screw holes? Are you embarrassed that it’s a Kawasaki? :whistle:
- HeavenlyMachines
21 May 2017 16:34
It's just Rattle Can job. If I had stripped it to bare metal I'll at least hire a booth to do 2K paint
Just curious what can be had for sub- $80 and elbow grease. It will be Duplicolor Acrylic Lacquer for quick drying.
- HeavenlyMachines
21 May 2017 16:35650ed wrote: Why remove the emblems and fill in the emblem depressions and screw holes? Are you embarrassed that it’s a Kawasaki? :whistle:
The screw hole is there!! I filled the depression as it seems to be where water got lodged = rust
21 May 2017 16:59
Oooops! My apologies. I thought your tank originally had a recessed area for the emblem like my KZ650 (see image below). I forgot that Kawasaki stopped doing that on later tanks. Ed
- HeavenlyMachines
21 May 2017 19:03
if my painting is 80% of that I'd be very happy
22 May 2017 05:19 - 23 May 2017 06:31
You can get a really nice shine using the Duplicolor paint, but it isn't fuel resistant at all.
I would topcoat with SprayMax 2k clear or some other 2-part urethane in a spray can.
ChuckHawks.com --- Harley Paintin' for the underfunded.
Duplicolor Truck Van & Suv is the paint I used, but a fuel spill ruined it. doh.
Last edit: 23 May 2017 06:31 by martin_csr.
