No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Backrest / Sissy bar fitment
  • RFE81LTD1K
  • RFE81LTD1K's Avatar Topic Author
Re: Backrest / Sissy bar fitment
18 Jun 2015 12:30
#677151
swest wrote: The Volvo one has openings that look cool, plus will help keep her back from sweating.
Definitely gonna have to look into those. Do you remember off hand how far apart the rods are?
81 KZ1000 LTD
All original.
15k miles.
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Jun 2015 12:47
#677152
I don't know about the Volvo ones but the one I got they were about 6" apart.
  • RFE81LTD1K
19 Jun 2015 12:26
#677292
swest wrote: I don't know about the Volvo ones but the one I got they were about 6" apart.
Something narrow like that would make fabricating a bracket somewhat easier. IIRC the narrower aftermarket backrest are about 8 1/4" wide at the base. Others wider. So making a bracket for a something that's 6" or less wide would be easier. Going to look into this as a viable option.
Maybe something like this;
Or this;
Thanks
Robert
81 KZ1000 LTD
All original.
15k miles.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2015 14:00
#677298
I just took a stroll down to Ecology Auto Wrecking and came home with what I wanted. New would have been better but $5 was worth experimenting with.
  • RFE81LTD1K
19 Jun 2015 14:15
#677306
swest wrote: I just took a stroll down to Ecology Auto Wrecking and came home with what I wanted. New would have been better but $5 was worth experimenting with.
Yeah, I won't order one off ebay. I'll do the same as you and go hand pick one.
81 KZ1000 LTD
All original.
15k miles.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2015 14:26
#677310
If you like it you can buy a brand new one. At that rate you can pick up a few. I like choices. B)
  • RFE81LTD1K
19 Jun 2015 18:04 - 19 Jun 2015 18:18
#677341
swest wrote: If you like it you can buy a brand new one. At that rate you can pick up a few. I like choices. B)
Might do that if I cant find a nice on in a salvage yard. Wonder if I could incorporate the locks too. Be nice to be able to raise/lower/remove it at will. ???
I'm thinking I could weld two pcs of tubing to the bracket and affix those inside of them. Depends on how they're originally mounted inside the seat and how long they are.
81 KZ1000 LTD
All original.
15k miles.
Last edit: 19 Jun 2015 18:18 by RFE81LTD1K.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2015 19:29
#677347
The locks for the head rest is screwed to the top of the seat.
  • RFE81LTD1K
19 Jun 2015 19:48
#677350
swest wrote: The locks for the head rest is screwed to the top of the seat.
Hmmm, that means I'd have to have some kind of a flange on top of the tubing that's the same diameter as the lock to screw it to. Plus find a way to keep the bottom of it stationary so it wouldn't wobble around inside the tubing. More rigid considering your head doesn't apply as much pressure leaning against it as your back would.
Sounds like it might be more trouble than it's worth. I'll figure out another way or go back to making a bracket for a more traditional backrest.
81 KZ1000 LTD
All original.
15k miles.
