Backrest / Sissy bar fitment
- RFE81LTD1K
12 Jun 2015 11:04 - 15 Jun 2015 12:03
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationQuick question ... Will a backrest/sissy bar off of a 1983 police bike fit on a 1981 KZ1000 K1 LTD? Mostly concerned about the mounting brackets themselves.
Same question for 1982 KZ750 CSR sissy bar mounting brackets.
Or these 1981 (?) KZ750 ??? mounts.
Thanks in advance.
Robert
Thanks in advance.
Robert
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
Last edit: 15 Jun 2015 12:03 by RFE81LTD1K.
- RFE81LTD1K
Re: Backrest / Sissy bar fitment
16 Jun 2015 22:13
Wow. Nobody huh? OK. How bout this, are there any KZ accessories prior to 1981 that will fit my bike? Or are the 81-82 ltd models bastard children with few adaptations with previous models?RFE81LTD1K wrote: Quick question ... Will a backrest/sissy bar off of a 1983 police bike fit on a 1981 KZ1000 K1 LTD? Mostly concerned about the mounting brackets themselves.
Thanks in advance.
Robert
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
17 Jun 2015 05:17 - 17 Jun 2015 05:18
I would ask the sellers for a bolt hole center-to-center measurement.
Of the two items linked above, the 750-CSR plates are probably going to be a closer match to a 1000 --- the 750-Twin frame is similar in size to the 1000s. The 81 plates are for a 750-4 which is a smaller bike, more akin to a 650 frame size.
Vintage K&G universal fit luggage racks & sissy bars can be found all over eebbaayy, being listed in all sorts of ways, usually depending upon what bike they were on. KZ, CB, GS, XS 550/650/750/850/900/1000/1100. Aschco is another brand --- their luggage racks look the same as the KG stuff.
Last edit: 17 Jun 2015 05:18 by martin_csr.
17 Jun 2015 06:37
I adapted a vintage luggage rack from a 350 Honda to fit my Z1. I had to cut the bushing off my old grab rail and weld it to the rack. There is a place to add a sissy bar but I wanted a top box. The one I ordered the advertised dimensions were wrong so it was too short. Had a big gap and it looked like SHT. Went down the the wrecking yard and got a head rest from a Nissan.
- jeff80kz1000e2
17 Jun 2015 14:25 - 17 Jun 2015 14:27swest wrote: I adapted a vintage luggage rack from a 350 Honda to fit my Z1. I had to cut the bushing off my old grab rail and weld it to the rack. There is a place to add a sissy bar but I wanted a top box. The one I ordered the advertised dimensions were wrong so it was too short. Had a big gap and it looked like SHT. Went down the the wrecking yard and got a head rest from a Nissan.
Nice job Steve looks real good. I will more than likely be fabricating some schtuff for a top case as well. I currently fabbed a bracket to hook up some hand me down willie max saddle bags for the old ST . Lookin good!
Last edit: 17 Jun 2015 14:27 by jeff80kz1000e2.
17 Jun 2015 14:34
Put up a pic of your bike, maybe we can come up with some ideas.
- RFE81LTD1K
17 Jun 2015 15:39 - 17 Jun 2015 15:55Here ya go ...swest wrote: Put up a pic of your bike, maybe we can come up with some ideas.
Attachment My81KZ1000K1LTD-2.jpg not found
Attachment 81KZ1000LTD-2.jpg not found
Been thinking about fabbing something like this;
Attachment 10728_kur_8998_tt_h_9_1350x900_RGB_72DPI.jpg not found
Attachment 16114_kur_16058980_ob_h_9_1350x900_RGB_72DPI.jpg not found
The bracket under the seat would be shaped differently but you get the idea. I'd keep the grab bar and utilize it for additional backrest support. I made a rough cardboard template and with a little creativity it is feasible. But as I said, the grab bar would have to help support the backrest up right keeping it from possibly bending the bracket down and riding on the fender.
It's something along those lines or fab some side brackets. To do that I'd like to keep the grab bar but haven't figured out a way to have both.
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
Last edit: 17 Jun 2015 15:55 by RFE81LTD1K.
17 Jun 2015 16:59
The grab bar does present a problem. Those brackets you were showing might work if they're long enough. Not much room there. My new grab bar is sitting on a shelf in the shed. Bought from Z1. No place for it to fit.
- RFE81LTD1K
18 Jun 2015 01:42Your right about there not being much room there. I'm not going to buy one of those $170 dollar brackets. Even if it was long enough I'd still have to modify it including welding on some additional tabs for mounting into the fender mounting holes. I only posted pix of it to give the general design of what I considered fabricating.swest wrote: The grab bar does present a problem. Those brackets you were showing might work if they're long enough. Not much room there. My new grab bar is sitting on a shelf in the shed. Bought from Z1. No place for it to fit.
I've looked at several different ways to fab something. The easiest would be side brackets. But at the price of removing the grab bar. A bracket based off that design wouldn't be that hard to make. Maybe I'll make another rough template but this time out of sheet metal. Meanwhile I'll stay on the hunt for one on ebay or cycle salvage yards.
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
18 Jun 2015 06:08
I looked at a lot of head rests at the wrecking yard. The Volvo one was the sexiest but was the wrong color. They all had long bars coming out the bottom of different shapes. The one I have had 13mm solid chrome bars. it had a hollow square bracket welded to the bars. I didn't need them so I took them out, put in a block of wood, (the seam is Velcro'd closed) and screwed the new pad to the box from the inside. My new back rest cost me $5. You might pick up a pad like mine (all kinds of styles to choose from) and start from there.
- RFE81LTD1K
18 Jun 2015 10:50I didn't really catch what you were saying about using a Volvo head rest in an earlier post. Do now and that's a pretty good idea. Like you said there's all kinds to choose from. It just has to be black.swest wrote: I looked at a lot of head rests at the wrecking yard. The Volvo one was the sexiest but was the wrong color. They all had long bars coming out the bottom of different shapes. The one I have had 13mm solid chrome bars. it had a hollow square bracket welded to the bars. I didn't need them so I took them out, put in a block of wood, (the seam is Velcro'd closed) and screwed the new pad to the box from the inside. My new back rest cost me $5. You might pick up a pad like mine (all kinds of styles to choose from) and start from there.
Thanks again.
Robert
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
18 Jun 2015 10:54
The Volvo one has openings that look cool, plus will help keep her back from sweating.
