Major modifications to tank / welding etc..
  • jydog
  • jydog's Avatar Topic Author
Re: Major modifications to tank / welding etc..
05 Jan 2012 22:01 - 05 Jan 2012 22:05
#496581
Well, I finally got the tank clean enough ( no gas smell ) to weld on. I cut the return and petcock out of an old gpz1100 tank with a whole saw and started to weld them into my tank with my mig welder. What a pain the arse. Every time I think I have it sealed up I put soapy water on the welds and pressurize the tank. 2 or 3 pinhole leaks every time. So I grind the welds down a bit and re-weld. More pinhole leaks...I must have done this 10 times. Next time I braze or solder. Is there anything I can put on these welds to make sure they are sealed up?
81 KZ1000 LTD
Griffin GA
Last edit: 05 Jan 2012 22:05 by jydog.
  • jydog
06 Jan 2012 17:58 - 06 Jan 2012 17:59
#496765
Well I got ticked off at the mig welding and went old school on the thing. My first try at brazing. I think my grandfather would be proud. He used to braze everything.
81 KZ1000 LTD
Griffin GA
Last edit: 06 Jan 2012 17:59 by jydog.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Jan 2012 18:05
#496767
u learn something new every day.
Well done. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • jydog
06 Jan 2012 18:14
#496770
mark1122 wrote: u learn something new every day.
Well done. B)
Thanks Mark, did you get your guages yet?
81 KZ1000 LTD
Griffin GA
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Jan 2012 18:53 - 06 Jan 2012 18:54
#496779
yes , as a matter of fact, they came last night. i havent even open them up yet. the mail lady left them at the side of the house ane i dindt notice them till i left this am.
Thanks
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 06 Jan 2012 18:54 by mark1122.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
09 Jan 2012 11:11
#497211
good job sealing the welds over with the brazing.
  • jydog
09 Jan 2012 11:22
#497213
531blackbanshee wrote: good job sealing the welds over with the brazing.
Only looks like I did. Still has pinholes. Maybe I'm putting too much pressure to it when testing
81 KZ1000 LTD
Griffin GA
  • 531blackbanshee
  • Vendor
  • Vendor
09 Jan 2012 12:11
#497217
dang it!
i have heard that the test pressure should be less than ten pounds.
  • jydog
09 Jan 2012 12:14
#497218
Did your tank flex when you put pressure to it? I may be using too much heat? Trial and error till I get it.
81 KZ1000 LTD
Griffin GA
  • Boostable
  • Boostable's Avatar
09 Jan 2012 12:15
#497219
You could always redcoat the tank. That will seal up any pin holes and might not be a bad idea just for extra security.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • jydog
09 Jan 2012 12:39
#497223
Boostable wrote: You could always redcoat the tank. That will seal up any pin holes and might not be a bad idea just for extra security.
I might be heading that direction. Next stop silver solder
81 KZ1000 LTD
Griffin GA
  • 531blackbanshee
  • Vendor
  • Vendor
09 Jan 2012 13:21
#497232
my tank never flexed while pressure testing it.
although i was using a innertube so it took the expansion,it would flex long before the tank would.
