Clutch's 1982 KZ750 E3 Cafe
- Motor Head
Re: Clutch's 1982 KZ750 E3 Cafe
08 Nov 2011 22:51
You did a good job with your bike, and now your getting the reward of riding. Hope the weather there stays good for you, have fun.
- clutch
- I wish I had a tad more patience to do it better!
09 Nov 2011 01:59Motor Head wrote: You did a good job with your bike, and now your getting the reward of riding. Hope the weather there stays good for you, have fun.
Thanks
The weather is gradually getting chilly here. It was pretty nice today, but I know the "too cold to ride" (for me) weather is coming soon. Hopefully I can figure out the issue with my tail light and get in a few more rides before storing for the winter. At least I still have plenty left to do on my '66 A1 project. LOL
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- clutch
09 Nov 2011 16:05
I was playing around with the tail light today, and it seems that the only time I have issues with the thing going out is when the ignition is running. I'm thinking that the way I have it wired will require a relay for the ignition, and hopefully that will fix the tail light issues I am having.
Wish List:
Wish List:
- Motor Head
09 Nov 2011 16:44
What is this an LED tail light assy? How's it wired, since you did your own wiring? Where is the feed for the power coming from, ignition switch, through fuse panel, to the brake switch, to the light? Then Tail is switched with the head light?
Measure the voltage where you connected the new light, using first the ground wire, then the chassis for the negative meter probe. Both Tail, and Brake. Then un-plug the brake wire from the light, then test there for power when the tail is on. Then reverse that, un-plug the Tail wire and test there when the brake is on. To see if it is back feeding. Could be a Diode issue.
- clutch
09 Nov 2011 16:49
There is a main fuse, then ignition switch. From the ignition switch, there is one main power wire going to a fuse block that powers everything. Since the ignition is so taxing, and the LED has low draw, I figured that I created a "load dependent" tail light circuit. This is why I was thinking that the relay may fix the problem. I will still run the meter testing, but will probably get the relay anyway.
Wish List:
Wish List:
- clutch
10 Nov 2011 02:49Motor Head wrote: What is this an LED tail light assy? How's it wired, since you did your own wiring? Where is the feed for the power coming from, ignition switch, through fuse panel, to the brake switch, to the light? Then Tail is switched with the head light?
I didn't do the unplugged part, but the brake side reads less than 1v (about .78v) when the tail only is on. The tail light reads battery voltage when brake is on, but I that is with it plugged into power. I will try the unplugged part next time I go out for a smoke. Hopefully it's not the light itself. I've only had it about a year and a half, so I would hate to be replacing that already!
Wish List:
Wish List:
- 750steve
10 Nov 2011 20:53
Clutch, just when im reading this i'll ask the question now.
I have an LED stop/tail light to fit & I'm hoping to wre it like this. Banjo bolt brake light switches for front & rear brakes both wired into the same relay to activate it. The power wire will then activate the stop light when the brakes are hit?
I've read some LED stuff about resistors & its messing my head up! :lol:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- clutch
10 Nov 2011 23:30750steve wrote: Clutch, just when im reading this i'll ask the question now.
The relay should work as you described, but it shouldn't be necessary with the stock wiring. I had mine hooked up with stock wiring and it worked fine.
Wish List:
Wish List:
- Motor Head
11 Nov 2011 11:55
You can also do a Bench test, off or on the bike. With some test leads to the battery, taking the other switches and wiring out of the equation.
- clutch
12 Nov 2011 17:05
With the brake light wire disconnected, it still reads .78v with the taillight on. Is this indicative of a bad diode?
Wish List:
Wish List:
- Motor Head
12 Nov 2011 17:10 - 12 Nov 2011 17:13Is this with the wire coming out of the Light assy, with the brake wire disconnected from everything?clutch wrote: With the brake light wire disconnected, it still reads .78v with the taillight on. Is this indicative of a bad diode?
Sure sounds like a Diode failure/ Leak. I don't know exactly what circuitry they use in the Assy, but if you can get the Assy apart to look at the circuit/ board. You can test the diodes, get a replacement for cents.
Of course each 1 of those bulbs/ LEDs is a diode.
Last edit: 12 Nov 2011 17:13 by Motor Head.
- clutch
12 Nov 2011 17:12Motor Head wrote:Is this with the wire coming out of the Light assy, with the brake wire disconnected from everything?clutch wrote: With the brake light wire disconnected, it still reads .78v with the taillight on. Is this indicative of a bad diode?
Ok I will pull the light off sometime soon, and post a pic of what I see (I will have no clue lol). I'm searching eBay for tail lights atm to see if there is something I like better than what I have though.
Wish List:
Wish List:
