Clutch's 1982 KZ750 E3 Cafe
- gwolever
Re: 1982 KZ750 E3 makeover--Complete--NEW PHOTOS!
27 Oct 2011 15:56
What a great looking bike! Very nice work! Definitely something to be proud of.
I like the idea of blacking the forks too.
But if you end up polishing, spend the $30 and get a bench buffer (Harbor Freight) and some aluminum polishing compound. Take those things off and polish the hell out of them rather than trying to do the job with a dremel polishing kit. Bench buffering large parts takes no time at all.
I would start with stripping any leftover clearcoat first though (paint stripper) and some fine wet sanding before buffer.
1982 KZ1000 CSR
- clutch
- I wish I had a tad more patience to do it better!
27 Oct 2011 18:38
Thanks guys. I really like the way it looks. I'm going to clean up the forks and then paint them black to go with the style. I just need to figure out that darn gas leak at the petcock first!
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- Godfrey
27 Oct 2011 18:55
Black them out , as with the other thing I mentioned , the more contrast in the bike the more it'll pop, sorry no experience with the petcock.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
- clutch
Re: 1982 KZ750 E3-LEAK- Petcock adapter plate
28 Oct 2011 16:06 - 28 Oct 2011 16:33
So I decided to give Permatex No 1 gasket maker a try. It is one of the very few that is specified as gasoline resistant. I applied a little more than "necessary", but I wanted to ensure a good seal for a proper test. They list this product as fully curing in 24 hours, but I am going to give it until Monday before I put any gas back in it, since it is a little on the cold side today, and I'm working all weekend anyway. I will let you all know how it turns out!
P.S.: I am going to just use this thread for any posts on my 750, so I don't keep adding more and more threads about it. LOL!
Wish List:
Wish List:
Last edit: 28 Oct 2011 16:33 by clutch.
- clutch
29 Oct 2011 14:32
A little update on the gasket stuff. So far it hasn't set completely, though I am just looking at the squeeze out. It is still a little on the pasty side, but it has been cold here. I think leaving it until Monday will be a good idea, but I will check on it again tomorrow to see if it looks to be curing.
Wish List:
Wish List:
- clutch
Re: Clutch's 1982 KZ750 E3 Cafe
29 Oct 2011 15:25 - 30 Oct 2011 02:56
SO, I'm thinking that I prematurely removed the warning light self checker from my 750. It appears that the low fuel light won't function properly without it. While examining the WD to try to figure out how I would wire it back in, I realized that my clymer's wd for my bike has the wiring for the oil pressure sensor and low fuel sensor circuits mixed up. Check it out!
750 E3 WD
And, while looking, if any of you electrical gurus can confirm that I would just hook up the brown to switched power, the middle y/b to the low fuel circuit, and the other y/b to ground. Is that correct? I got a little turned around because of the whole mixed up wd thing lol!
EDIT: Or do I really not need it? I'm not sure how much gas was actually in the tank when it came on....
EDIT #2: Or maybe I wired it backwards and that makes it stay on all the time? Not sure why that would make a difference though. When the gasket stuff on my petcock adapter dries, I will put some gas in, and go for a ride to fill it up. If the Light stays on, I will try switching them first to see if it makes a difference...
750 E3 WD
Wish List:
Wish List:
Last edit: 30 Oct 2011 02:56 by clutch.
- clutch
30 Oct 2011 03:51 - 30 Oct 2011 03:51clutch wrote: A little update on the gasket stuff. So far it hasn't set completely, though I am just looking at the squeeze out. It is still a little on the pasty side, but it has been cold here. I think leaving it until Monday will be a good idea, but I will check on it again tomorrow to see if it looks to be curing.
I just went out to the garage and tried to torque the adapter plate bolts down a little more. They are as tight as they will go, so I'm hoping that means the gasket material has set. If I have a little time before work tomorrow, I will put some gas in it to see how it holds up...if not, I will do it on Monday. Either way, I will update on how well the stuff sealed the tank for me.
Wish List:
Wish List:
Last edit: 30 Oct 2011 03:51 by clutch.
- Motor Head
30 Oct 2011 11:42
Did you get your Low Fuel Light straightened out?
The reason for the err in the Clymer is it is that way from Kawasaki. here is the Kaw version in Filebase: www.kzrider.com/filebase/doc_download/311-z750e3
Same mixed up diagram.
Brown is Ignition switched 12v, the two Black/ yellows from the sensor in the tank, one to ground ie chassis, and the other to the bulb. So the bulb has switched 12v to the center, and the Black/ yellow from the tank to the outer case.
- clutch
30 Oct 2011 14:17Motor Head wrote: Did you get your Low Fuel Light straightened out?
Not quite yet (still need to put some gas in the tank), but after thinking about it for a while, I wonder if it has something to do with using an LED indicator instead of the standard type bulb? My understanding is that it somehow works off of resistance, and resistance is very low with the LED's. I know the wiring is correct, as I did it custom..just not sure if it makes a difference which one off the sensor comes from the indicator, and which goes to ground.
Wish List:
Wish List:
- Motor Head
30 Oct 2011 15:05
You may already know this, but LED is Light Emitting Diode, so it makes a difference which way the current flows through the LED bulb. It will only work in one direction.
Like I said you probably know this. :whistle:
- clutch
30 Oct 2011 15:07Motor Head wrote: You may already know this, but LED is Light Emitting Diode, so it makes a difference which way the current flows through the LED bulb. It will only work in one direction.
Right. I know that part is wired correctly, because the indicator comes on. I'm just not 100% sure that it is going off when it should (not low on fuel).
Wish List:
Wish List:
- Motor Head
30 Oct 2011 15:27
So it is staying ON? That might be because of the small resistance still in the Thermistor. Maybe wire it up to either a relay or a transistor to switch it, on/ off.
