Kz1000 Carbon Fiber Fuel Tank
  • porchev914
  • porchev914's Avatar Topic Author
Re: Kz1000 Carbon Fiber Fuel Tank
13 Sep 2010 20:59
#398447
trianglelaguna wrote:
when i was younger...i liked to trim off extra brackets and swap for lighter parts....seems...like a waste of time these days to try and trim 50-75 lbs off of the bike...
I here ya, the cheapest 20lbs I could loose would be off my ass! :laugh:
I'm glad you enjoyed the pics elfmagic ;) If you liked the bottom, the top piece will send you over the edge :laugh:
I ordered some supplies from Applied Vehicle Technology www.avtcomposites.com/index.php3 this morning....basically resin, activator, 3 yards of carbon fiber, sealing tape and strechy bagging film. It was supposed to go out today, with 3-4 days shipping to Cali. Hopefully I'll get the supplies Wednesday. Then I might have a tank top made by Friday....that would be a monumentous milestone for me :woohoo:
FRANKEN Z!
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
13 Sep 2010 22:50 - 13 Feb 2012 19:32
#398513
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 19:32 by KZ250LTD.
  • porchev914
13 Sep 2010 23:28
#398517
Thanks KZ250LTD, and that is a great question. The halves will be bonded with the same epoxy used to laminate, but with a high density filler added to give it body. When I drip this stuff on my driveway and forget to clean it, I have to chip it off with a hammer. It usually comes off in one piece, but it always takes a bit of my concrete driveway with it.
FRANKEN Z!
  • irishwill
  • irishwill's Avatar
14 Sep 2010 09:35
#398632
awesome work!
I am speechless....what a crew we have here....fantastic!
  • porchev914
14 Sep 2010 10:51
#398650
Thanks Ben, I am trying my best :laugh: I feel the same way when I look at your aluminum. :P
FRANKEN Z!
  • ScottyKZ1000A2
  • ScottyKZ1000A2's Avatar
14 Sep 2010 12:17
#398664
I have been watching you build this impressive carbon fiber KZ and I must admit I bow to you.
I am so impressed that I have started to wrap my 78 KZ1000 with carbon fiber, I know that it will add weight but I don't have the time or skill to build it like you. At least it will look cool like yours.
Keep up the great work.
  • irishwill
14 Sep 2010 15:01
#398706
well I just want to put my name on the list officially.....I WANT A SET!!!
Ive got this Idea...your body work...bst wheels....how light can we make one??
B)
  • porchev914
14 Sep 2010 16:22
#398723
Thats great!! Don't worry about the weight, it won't be much. The most important part is taking that first step. Once you get a little experience with the materials, you'll start to feel more confident doing more complex parts, then move into molds if you like it. This is just the beginning B)
FRANKEN Z!
  • porchev914
14 Sep 2010 16:52 - 14 Sep 2010 16:57
#398730
B)
BST wheels...Drooooooooooool.... I don't quite have the facilities to make such bike candy :pinch:
How light can we make one? Well, ditch the stock mild steel frame and make a Bimota-esc carbon perimeter frame from head stock to swingarm pivot. Hang the engine like a stressed member, carbon subframe, modern lightweight monoshock rear and USD front suspension, BST wheels and a $HIT LOAD of money and time :laugh: :laugh: :laugh:
I'm not sure how to get around the Mississippi wide, boat anchor of an engine though :whistle:
FRANKEN Z!
Last edit: 14 Sep 2010 16:57 by porchev914.
  • irishwill
14 Sep 2010 19:52
#398796
well the boat load of money will be a deterent....although I have seriously thought about a spondon frame ....
im ok with the fact it will never be a modern sportbike....holding the title of COOLEST bike will have to do!!!
I think a bike with your body work ('73 colors with the carbon showing through the candy rootbeer)mono shocked rear usd front rear sets custom pipe and bst wheels would be as close to perfect as I can hope for!
  • porchev914
14 Sep 2010 22:12 - 15 Sep 2010 10:47
#398815
That sounds like a pretty effing sweet plan to me :woohoo: :woohoo: :woohoo:
A bike like that would need to have some sac, I'm not putting my name on some poser bike :ohmy: :dry: :P
Who am I kidding? I'd put this stuff on anything B)
FRANKEN Z!
Last edit: 15 Sep 2010 10:47 by porchev914.
  • rslingshot
  • rslingshot's Avatar
16 Sep 2010 17:46
#399184
testarossa wrote:
porchev914 wrote:
DoubleD, EVERY aspect of the mold gets imparted to the piece being molded. Every scratch, every dip, every pinhole, every imperfection is reflected in the laminated part. That is why mold quality is of paramount importance, ESPECIALLY a piece that is designed to show the fabric weave. The square you speak of is the rear tank mount. It is a secondary patch of steel spot welded to the main underside panel to reinforce the rear mount. I took off the mount, but I left the reinforcing steel patch there because it hase locating pins for the rear mount. The patch however had a small gap, and if that gap were to fill with resin, it would have locked the mold to the tank (not my idea of fun times) so I filleted the gap around the steel panel with modeling clay. So the texture you are looking at was imparted by the modeling clay, and I was too lazy to sand it all smooth :blush: Look at me, getting lazy :S
This is why molding equipment and specifically the molds themselves are soo expensive. There is a TON of finishing work to removing tooling marks from machined molds. As porchev says, if its on the mold, then it's on every part out of the mold. I wind up machining small plastic parts almost daily because the batch size is not big enough to justify the expense of molding. Some of those batches are for 5000 pieces, and that still isn't enough.
You could not be more correct. There is more hand finish work on molds or stamping dies then most people would ever imagine. The molded part itself is not really that costly it's the upfront tooling cost that kills you. I have been in the tool and die trade for 21 years now (injection molding) And I have to tell you what Adam is doing is not an easy thing to do. I don't know much about resin transfer molds but it looks like you are doing a hell of a job, keep up the good work.
