Painting My Bodywork
  • DoubleDub
  • DoubleDub's Avatar Topic Author
Re: Painting My Bodywork
06 Aug 2010 16:51 - 06 Aug 2010 16:53
#388765
Once this cures and is wet sanded, I will evaluate the situation and decide whether or not I need a third coat. If not, it's on to the stripes!
In the mean time I will finish prepping my side covers and tail piece and get some primer laid on them.
Last edit: 06 Aug 2010 16:53 by DoubleDub. Reason: Holy edit, batman! Decide what you want to write the first time!
  • PLUMMEN
  • PLUMMEN's Avatar
06 Aug 2010 17:13
#388771
DoubleDub wrote:
And, after drying from wet sanding and tacking with a 3M Tack Cloth
( www.shop3m.com/70070595015.html?cshift_ck=null&client_id=5093 - available locally at Farm & Fleet )
The second coat of Duplicolor Graphite Wheel Paint - looking pretty good if I don't say so myself!
looks good so far B)
  • DoubleDub
06 Aug 2010 20:21
#388832
Got the side covers prep'd and sprayed with the first coat of primer. I have to get some more primer before I move on to the tail (and I'm running out of space on my saw-horse-table, plus the wife wants to park in the garage again...)
  • PLUMMEN
  • PLUMMEN's Avatar
06 Aug 2010 21:09
#388840
whats wrng with the street? :woohoo:
  • DoubleDub
06 Aug 2010 21:30
#388847
Not sure...I think she thinks we live in da'hood or something. The neighbors even have kids who might do hooligan type things.
  • Old Man Rock
  • Old Man Rock's Avatar
07 Aug 2010 05:42
#388875
DD... you did scuff and use adhesion promoter on that plastic right?
(BTW, there's only one answer...YES)...:laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • DoubleDub
07 Aug 2010 09:17
#388925
Yes...an no. Last time I used it - this time I didn't take it down below the previous primer when prepping the surface so I didn't.
Any reason this should be a problem?
  • porchev914
  • porchev914's Avatar
07 Aug 2010 12:15
#388972
If you're spraying on properly prepared and sound old paint, you don't need adhesion promoter
FRANKEN Z!
  • DoubleDub
07 Aug 2010 21:32
#389214
So the side cover that I epoxied...yeah, well the epoxy is shit, basically. I sort of expected this when I applid the epoxy, but I thought "why not try it?".
Anyways...in the line of "why not try it?" I just tried using my soldering iron to "weld" the crack back together on the front and the back. Being my first ABS "Weld" job, I'm not positive it looks good. I'm going to let it cool and then flex it a bit before I pass final judgement. It will definitely need to be cleaned up before priming again.
  • DoubleDub
09 Aug 2010 19:37
#389769
The solder-welding seems to have worked as long as I don't torque the side cover too much. I'll just have to be careful removing it (which I'll want to be to keep the helmet hook from gouging the pretty paint I'm working on...)
Anyways...now that it's one piece again, I put another coat of primer on it after trying to work out the roughness my clumsiness caused with the soldering iron. I also sanded the tail and put the first coat of primer on. It looks...well, like primer, so I won't waste the precious storage/bandwidth with a photo of it.
Letting it dry - the humidity jacked up again around here (wicked storms last night) so I have to take it slow and let it dry out. Once it stops stinking so much I might be allowed to bring it into the basement to dry it out.
  • porchev914
09 Aug 2010 20:04
#389776
Well, if you need a bolt on style cover.... :laugh: :laugh: J/K, screw the bandwith, give us some pics!
FRANKEN Z!
  • DoubleDub
10 Aug 2010 19:42
#389994
Okay, first, back side of the repair work on the side cover. The crack wasn't large, but they seem to grow so I wanted to get it taken care of. The soldering iron actually worked pretty well, it's just not pretty when I do it :P
