Clear Coat
  • ronjones
  • ronjones's Avatar Topic Author
Clear Coat
03 Apr 2007 16:50
#126257
I'm in the process of doing a rattlecan repaint on my bike, tank and sidepanels. It's turning out pretty good and I don't want to mess it up now. I've put the clear coat as per instructions, several thin layers and then followed by several medium layers. Everything has gone on quite evenly and I now have kind of a "pebbly" texture to the finish. According to the directions I could finish it w/compound but I'd like to put a few more coats of clear to deepen the finish. My plan is to use 1000 grit wet sand paper and then add more coats of clear.
2 questions:
Am I correct in using the 1000 grit paper to prep for more clear coat?
I kind of like the pebbly satin finish that's on there now and would like to know if there is any reason not to leave the "pebbley" finish or is it a necessity to compound it for a shiney finish?
Thanks
Ron
  • Pterosaur
  • Pterosaur's Avatar
Re: Clear Coat
03 Apr 2007 17:00
#126259
ronjones wrote:
2 questions:
Won't hurt anything. Personally, I'd go #600 wet, but as long as it's scuffed well enough, it'll do.
I'd give the job time to set. At least a week, as much time in the sun as you can reasonably give it.
The techical term for that texture is "orange peel". Trying to remove it by compound alone will likely take you all day - and not guarantee not sanding through the clear. I'd use that #1000 wet with a soft rubber pad to wet/block sand the clear *gently* - wetting often and wiping with a soft, dry rag to see if the peel's out. Then compound lightly, then polishing compound, then finish with glaze/swirl remover. Wait another two weeks at least before waxing.
Ultimately, there's only one person your paint job has to satisfy - and that's you.
If you like it - run with it. ;)
  • RonKZ650
  • RonKZ650's Avatar
Re: Clear Coat
03 Apr 2007 18:08
#126271
Only trouble here is you've effectively used up 1 weeks useful life of the repaint job. You do not have that much useful life, so be very, very careful. A rule of thumb is no gas should ever get near the tank, no rain and no sun. For best life, only ride at night on very clear nights with no chance of rain and use some aux. method of fueling like the popular gas can in a backpack with quick disconnect hoses.
I'm sorry guys, it's one of my moody "paint drives me MAD days".
:P
  • Pterosaur
Re: Clear Coat
03 Apr 2007 18:21
#126274
:P
Ron, I gotta admit you had me for a minute.
I read that first line and thought... well, you don't wanna know what I was thinking. ;)
I'll even back up the calendar a couple of days and give you an *April Fools!* on that one.
Good one.
  • wireman
  • wireman's Avatar
Re: Clear Coat
03 Apr 2007 18:22
#126275
:woohoo: :silly: :woohoo: :silly: :woohoo: :woohoo: :silly: :woohoo: :silly: :pinch: :P
  • ronjones
Re: Clear Coat
03 Apr 2007 19:11
#126287
Thanks for the reply, PT. So, if I understand you correctly, I just need to scuff it and don't have to get the peel out before I apply more clear.
After I finish coating the tank, if I want to get the orange peel finish out I should follow your instructions as far as sanding, then compound then swerl remover before waxing. If I want to leave the orange peel texture, just wax after a 2 week cure, of the final coat? Are there any downsides to leaving this texture, other than people telling me I didnt fininsh the job:)?
Thanks again
  • ronjones
Re: Clear Coat
03 Apr 2007 19:24
#126289
:P
LOL :) Ron, I knew I was gonna catch it form y'all paint purists:). I asked 2 motorcycle painters and they wanted $1400-1800. Even the guy that works at a car shop and paints bikes, at home, wanted $400...not gonna do it. BTW last year when I thought I was gonna be able to get her on the road quickly, I did a half ass job using the same paint. I did spill gas on it and it seemed to hold up pretty good and I hadn't used clear on it. So I'm hoping for the best.
Thanks for your comment, though.:)
RonJ
  • Pterosaur
Re: Clear Coat
03 Apr 2007 19:28
#126291
Correct.
Correct.
Remember that any kind of sanding/compunding/polishing is is *removing* applied material, so if you plan on sanding/polishing, it's okay to go a bit wetter and heavier with your coats. Don't worry as much about how it looks - you're gonna sand it again anyway, and don't dreak if you get a run or a droop - take a popsicle stick or some likewise flat item, wrap it with sandpaper and carefully sand it to the contour *FIRST* - then sand the remainder of the piece.
Correct.
Are there any downsides to leaving this texture, other than people telling me I didnt fininsh the job:)? Thanks again
Downsides? Not really - if you're happy with it, then what else matters?
Actually, the UP-side is that if you get tired of the finish or other people's bigotry, you can always "finish" the job at a later date - you're not losing options, per se - you're gaining 'em.
You betch'a. ;)
  • ronjones
Re: Clear Coat
03 Apr 2007 19:56
#126297
Believe me, PT, I've learned quite a bit about priming/sanding...painting/sanding, recently :). You shoulda' seen the rust pitting I built up w/primer and sanded smooth :(:)
A buddy mentioned that the texture might hold dirt.
Cool, I thought the same thing;).
You betch'a. ;)
Thanks again:)
Wish I could figure out how to do serial quotes and replys :blush:
  • Pterosaur
Re: Clear Coat
03 Apr 2007 20:07
#126300
Oh, I'd believe it.
And you're likely to learn a bunch more before it's over. But that's not a bad thing - there's only one road to experience, and that's in the doing. You can read every book in the world, I cab type till my fingers fall off, but you still gotta *do it* - and the bigger part of learning how to do it is how to learn from the mistakes you'll make and avoid 'em next time.
True, after a fashion, I suppose - but they still have soap and water in Maryland don't they? They did last time I was there. Wash it every so often - works wonders on dirt. ;)
If you ride motocross with it, or leave your bike sit under a tree for a couple of months fathering sap and bugshit, sure it'll get nasty. Any paint job would.
I wouldn't be that concerned about it.
Kinda like paint jobs - they take a little practice. :P
  • AR15Ron
  • AR15Ron's Avatar
Re: Clear Coat
03 Apr 2007 22:08
#126321
I am a firm believer in good enough is good enough :)
Seems like everytime I try to make my paint job close to perfect I ruin it and have to start over. I decided to leave the orange peel and just be happy its shiny before I wreck it again LOL
Wheres the pics? We need pics.
Ron
  • Mark Wing
  • Mark Wing's Avatar
Re: Clear Coat
03 Apr 2007 22:26
#126324
Go light whrn wet sanding the clear. The spray can clear isn't very thick and you don't want to break through. Just scuff it up and re-clear.
Mark
Yorba Linda Cal.
