Frames?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Frames?
10 Dec 2006 07:31
#98649
Bob. I have started making my own motor mounts out of 1/2" alluminum.Can you tell me what size bolt diam. you upgraded to?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Frames?
10 Dec 2006 08:11
#98671
i upped all mine to 7/16" on the front ones including the long one going through cases,made my mounts out of 3/8" stainless steel ;)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Frames?
10 Dec 2006 08:21
#98675
thanks.Are you doing anything to the sheet metal on the neck?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • BohicaBob
  • BohicaBob's Avatar
Re: Frames?
10 Dec 2006 08:55
#98682
mark1122: I bought my Z1/KZ engine mounting kits so I don't know offhand what the bolt diameter (s) are/were. But I could go out into the garage and measure the bolt diameters used in the Kosman Engine Mount Kit that I have in a box if you want me to.
  • kyradawg
  • kyradawg's Avatar Topic Author
Re: Frames?
10 Dec 2006 09:28
#98686
If I remember correctly The bolts in my kosman kit are 11mm.
Peace&Love:) , Darren
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Frames?
11 Dec 2006 08:24
#98986
Does this require drilling the frame holes bigger?
How about that neck sheet metal area guys? anyone tackled this yet?
Post edited by: mark1122, at: 2006/12/11 11:26
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kyradawg
Re: Frames?
11 Dec 2006 08:31
#98991
Yes you have to drill the holes in the frame out as well as the the holes in the engine. My sheet metal bracing is cracked from too many hard wheelie landings but from what Ive been told it's not an uncommon problem.
Peace&love:blink: , Darren
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
Re: Frames?
11 Dec 2006 09:10
#99003
wireman wrote:
steell wrote:
It's interesting that the GPz750 Turbo already has most of the bracing shown in the Klosman diagram, along with a larger backbone (upper frame tube). And it's noticeably heavier than the non turbo GPz750.
the added strengh and ability to actually put the power to the ground more than makes up for the few extra pounds .if you have to fight the chassis to get it to work for you you will never reach the full potential of what the bike and motor can do.:evil: all the fancy upside down forks and single shock swingarms in world will do you any good if youre frame cannot handle the loads put upon it ;)
Indeed, this is one of the problems I ran into with my Yamaha Seca Turbo: They used a stock Maxim 650 frame which may as well have been made out of slinkies. A buddy of mine had one just like mine and he learned the hard way to never try and follow a GSX-R 750 through a twisty canyon road!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • wireman
  • wireman's Avatar
Re: Frames?
11 Dec 2006 12:30
#99035
How about that neck sheet metal area guys? anyone tackled this yet?<br><br>Post edited by: mark1122, at: 2006/12/11 11:26
check my turbo project post,we are in the process of tackling headbracing right now;)
  • Maverick
  • Maverick's Avatar
Re: Frames?
11 Dec 2006 21:28
#99128
So I'm starting a winter project. It's a GPZ Streetfighter. Here's a pic of the frame
[img]
It's an '82 GPZ 1100. Looks like it has some of the frame rigidity addressed by additional cross-members and dual front engine mounting brackets. Any recommendations for additional bracing? I'm thinking about a couple possibilities: a cross member and possibly diagonal brace behind the carbs near the rear engine mount; some gusseting in the corners of the 'rear triangle;' possibly removing the thin sheet metal at the head tube and gusseting with heavier guage cro-mo. Is any of that really necessary? I'll eventually be dropin' in a 1175 wiseco kit in with a hot street cam (not sure which one yet). Will be mounting a zepher 1100 swingarm, and a modern USD fork from a zx10. Curious to hear your thoughts.
Cheers,
Mav
Post edited by: Maverick, at: 2006/12/12 00:35
Post edited by: Maverick, at: 2006/12/12 00:38
1981 KZ1000M1
  • Maverick
  • Maverick's Avatar
Re: Frames?
11 Dec 2006 21:38
#99129
1981 KZ1000M1
  • Maverick
  • Maverick's Avatar
Re: Frames?
11 Dec 2006 21:39
#99130
Gonna have to strip that red paint!!!
1981 KZ1000M1
