1978 KZ 1000 B2 Main Stand
  • Mikaw
  • Mikaw's Avatar Topic Author
25 Aug 2019 12:06
#809823
can any one tell me the thread size of the main stand bolts, I painted the chassis and need to chase the threads
  • TexasKZ
  • TexasKZ's Avatar
Re: 1978 KZ 1000 B2 Main Stand
25 Aug 2019 12:21 - 25 Aug 2019 12:34
#809824
The parts diagram does not show a main stand on the B2, but I would have assumed that it would mount with a pair of large shoulders bolts with a 14mm nut on the end. Is that not how yours mounts?
Last edit: 25 Aug 2019 12:34 by TexasKZ.
  • Mikaw
25 Aug 2019 19:13
#809850
I noticed the part break down doesn't show the B2 with a main stand. Maybe I have misidentified my bike, Im using the main stand temporary while I replace the steering head bearings and rebuild the forks. I took the shoulder bolts to the local hardware and couldn't get the bolt to thread into a 14-1.50 nut, but a 9/16-18 would fit. the nut wouldn't thread on a 9/16 bolt. im confused.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Aug 2019 19:44 - 25 Aug 2019 19:46
#809851
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThis is what you need.
Last edit: 25 Aug 2019 19:46 by SWest.
  • hardrockminer
  • hardrockminer's Avatar
25 Aug 2019 19:56
#809852
LTD versions didn't have a center stand but the mount brackets are there if you want to install one. I put one on my B4 so that I could keep the carbs even when the engine is shut off.
  • Mikaw
25 Aug 2019 20:36
#809854
hardrockminer… thanks for the info. I might leave it on but noticed it will hit the drive chain when in the upright position. is there a stop missing somewhere???
SWest Actually the bolt number is 34019-014... I have all the pieces, what I need Is the thread size so I can chase the threads in the tabs on the frame. they haven't been used in years and besides all the road crud, and rust there is also paint in the threads, At $40 a pop for bolts I want to clean up the threads in the tabs so I don't ruin the shoulder bolts.
  • Mikaw
27 Aug 2019 18:57
#809976
So have I stumped the greatest forum???
  • hardrockminer
27 Aug 2019 19:36
#809977
There is an aftermarket bracket you can buy and install on the exhaust pipe attachment hole. I bought one from Johnny's Cycle but others make them. Or you can just fabricate one if you're handy with metal work. (I'm not.)
  • old_kaw
  • old_kaw's Avatar
28 Aug 2019 06:59 - 28 Aug 2019 14:51
#809989
Mikaw wrote: So have I stumped the greatest forum???
Hardly stumped. Steve posted a pic of the nut and bolt at the beginning of the thread. My friends can't always remember the different metric bolt sizes / pitches, but never fear google is sometimes your friend. They say dementia is one of the first things to hit. Some politicians even don't know what state they are in. lol
It is 10mm, and it is considered fine thread so the pitch would be 1.25.
This is the nut the center stand uses. It is a 10mm X 1.25 fine thread self locker.
www.partzilla.com/product/kawasaki/92019...0747dca0ee0b882c07c5
www.google.com/search?q=Kawasaki+10mm+bo...ceid=chrome&ie=UTF-8
Bolt Diameter Standard Thread Pitch (mm) Fine Thread Pitch (mm)
7mm 1.00 -
8mm 1.25 1.00
10mm 1.50 1.25
12mm 1.75 1.50
EDIT: I tried to align the tabbing on the thread pitches but the software keeps bunching things up when I do. <sigh>
*Kawasaki used 2 different bolt pitches, as did most Jap bike builders. To mix in a bunch of oddball pitch sizes would be a logistics nightmare for any manufacturer. One thing I can assure it is NOT a 3/8 NF fastener.
In re-reading the OP comments.. You are confusing the bolt head sizes with the fastener size. A 14 mm hex head is a 10mm bolt (normality) A 9/16 hex head bolt is a 3/8" bolt. It seems that the only person stumped on this thread is the OP on correct fastener sizing.
1981 Kawasaki Kz1000K1
Last edit: 28 Aug 2019 14:51 by old_kaw. Reason: hmmmmm
  • TexasKZ
  • TexasKZ's Avatar
28 Aug 2019 12:46 - 28 Aug 2019 13:00
#809995
It could also be 1.0 or 0.75
www.fullerfasteners.com/tech/basic-metri...ead-chart-m1-m100-2/
Evidently, ther is also 1.12 and 0.5, though I bet they are pretty rarely seen in the U.S.
www.engineersedge.com/hardware/metric-ex...al-thread-sizes1.htm
Last edit: 28 Aug 2019 13:00 by TexasKZ.
  • TexasKZ
  • TexasKZ's Avatar
28 Aug 2019 12:54
#809996
Here is a printable chart, though you will need a really good printer for the small stuff.
www.boltdepot.com/fastener-information/P...ric-Thread-Sizes.pdf
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
28 Aug 2019 13:28
#809997
You can use a thread/pitch gauge for metric and whitworth to get the right pitch.
