Fork upgrade alternatives to swapping?
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
08 Sep 2016 13:38 - 09 Sep 2016 06:42
#741576
It's getting colder and I'm trying to get s jump on plans to rebuild my dual shock GPz. I'm pretty sure I don't want to swap the forks or swing arm.
I have some ZRX shocks on it already. What would be the best way to freshen up and upgrade the front suspension without retrofitting something from a new model?
Last edit: 09 Sep 2016 06:42 by GPzMOD750.
  • Julian_Boolean
  • Julian_Boolean's Avatar
Re: Re:Fork upgrade alternatives to swapping?
08 Sep 2016 13:51
#741580
Hyper Pro springs and oil.
The following user(s) said Thank You: GPzMOD750
  • martin_csr
  • martin_csr's Avatar
08 Sep 2016 13:56
#741582
Cartridge emulators are supposedly a very good upgrade. Racetech is the only place I've heard of that sells them.
08 Sep 2016 18:26
#741625
Start with the basics - when is the last time the fork oil was flushed out and replenished with the correct amount and weight of fork oil? If that is not done periodically the front forks will not perform well. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Sep 2016 19:23
#741636
Progressive fork springs.
  • 80B4
  • 80B4's Avatar
Re: Fork upgrade alternatives to swapping?
08 Sep 2016 21:08
#741647
Race Tech emulators, inner and outer bushings, new correct rate springs, seals, wipers, and fluid. The RaceTech parts are very high quality. Have the steering head bearings been serviced?
1980B4 1000
1978 Z1R
1978 B3 750
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Sep 2016 06:12
#741679
Besides what was mentioned, a steering damper is always a plus.
Have you serviced the shocks? I found 2 blown bladders in mine.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • GPzMOD750
09 Sep 2016 06:47
#741681
The only thing I've done is the seal on the one side.
It handled very well up to now so I've left everything else alone. But I'm going to go through it stem to stern this winter and make repairs and up grades that aren't too crazy or take away from the vintage appearance, hence the reason for not wanting to change the fork or swingarm.
My goal is a vintage twist on a street fighter.
  • GPzMOD750
09 Sep 2016 06:51
#741682
And I have been thinking about a steering damper.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Sep 2016 07:58
#741685
You can use this part number for a replacement bladder: 120104600101
They are a little longer but work and aren't $100/ea from RaceTech.
1975 Z1 900
2004 KX125
  • GPzMOD750
10 Sep 2016 05:16
#741760
Are the bladders for the shocks? I'm not having any issues there. or with the front either but I figured since I'm going to be doing a ton of work it'd be nice to bring my front end up to par of the rear.
The RaceTech site is confusing. Just a bunch of part numbers and specs. No actual cross reference to makes and models of bikes. Anyone know which emulator kit I would need?
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Sep 2016 06:10 - 11 Sep 2016 06:10
#741828
The bladders are for the shocks, they are known to go bad. If you dont have a nitrogen charge the bladder is split.
For the RT site, go to Product Search and select your bike info. www.racetech.com/ProductSearch/2/Kawasaki/GPz750/1982
1975 Z1 900
2004 KX125
Last edit: 11 Sep 2016 06:10 by Kidkawie.
