Fork upgrade alternatives to swapping?
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
Re: Fork upgrade alternatives to swapping?
11 Sep 2016 06:31
#741831
Kidkawie wrote: The bladders are for the shocks, they are known to go bad. If you dont have a nitrogen charge the bladder is split.
For the RT site, go to Product Search and select your bike info. www.racetech.com/ProductSearch/2/Kawasaki/GPz750/1982
Thanks, Idk why i couldn't figure out how to do that. The price isn't bad at all considering.
I'm not having any issues at all with the rears but maybe I'll get the them to keep them on hand.
  • 80B4
  • 80B4's Avatar
Re: Re:Fork upgrade alternatives to swapping?
11 Sep 2016 08:19
#741838
Kidkawie wrote: You can use this part number for a replacement bladder: 120104600101
They are a little longer but work and aren't $100/ea from RaceTech.
Thanks for this info! Where are you buying these bladders, I've tried looking that number up on a Kawasaki parts site with no luck.
1980B4 1000
1978 Z1R
1978 B3 750
  • GPzMOD750
11 Sep 2016 08:51
#741839
I found it on eBay right off.
The following user(s) said Thank You: 80B4
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
11 Sep 2016 15:22
#741884
Its a KYB number, not Kawasaki.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • 80B4
  • 80B4's Avatar
11 Sep 2016 19:48
#741908
I've found them, thanks!
1980B4 1000
1978 Z1R
1978 B3 750
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
12 Sep 2016 08:58 - 12 Sep 2016 08:59
#741952
Did you guys do the lowering mod to your shocks? I forget the exact measurements but the ZRX shocks are like 1/2" to 3/4" longer. Mine we "useable" but with no weight on the bike I had contact between my muffler and axle. I did the lowering mod by cutting off the original preload nubs on the shock, ran that for a bit, then found the inner sleeve flopped around. I wound up welding the inner sleeve and outer preload adjustment ring together. That's when I did the major overhaul on them.
Also, I just spaced theleft shock out with washers to clear the chain guard.
1975 Z1 900
2004 KX125
Last edit: 12 Sep 2016 08:59 by Kidkawie.
  • GPzMOD750
12 Sep 2016 09:16
#741953
I got them specifically for the extra length. I had extenders before.
My muffler doesn't go back that far and I don't currently have a chain guard.
