1978 KZ1000 a2 swingarm swap
- Paulb450
Re: 1978 KZ1000 a2 swingarm swap
22 Aug 2013 03:20
Thanks Leon. I did run the chain and seemed fine except that I need an offset front sprocket to line up properly with the rear. I will double check that its clearing the shock mounts. I wanted to raise the back end of the bike up a bit to give it a "tougher" stance.
Bluezbike, more pics of my old XR below, first one is what i started with. I am probably getting ahead of myself but planning out paint schemes and was thinking of doing something along the lines of the Hondas fuel tank, Bright Candy apple mettalic green with either white or silver scallops.
Attachment CIMG0670.JPG not found
Attachment IMG_00000041.jpg not found
Attachment IMG_00000039.jpg not found
23 Aug 2013 10:28
the honda is a beautiful piece of work sir :evil: !!!
very nicely done.
if the chain clears you are good,coulda just been the angle of the photo.
keep us posted,
very nicely done.
keep us posted,
- Paulb450
01 Sep 2013 13:39
Progress has been slow, had to order the offset sprocket from eBay so it is still a week away, got the 530 16t 1/4 offset coming with a new chain. I still don't understand gearing with the change of wheel sizes, i am hoping i am going to be ok with running 16/40. I don't expect to do any highway riding.
I did get some electrical bits installed, dyna system installed, points and condenser gone! The leads seemed very brittle and the new ones should help.
Attachment image_2013-09-01.jpg not found
Attachment image_2013-09-01-2.jpg not found
- Paulb450
02 Sep 2013 10:57
I decided to go with Renthal Ultra-Low bars, mounted them with some bar mounts sourced from a KTM which has had Fatty bars fitted. The grips on the pics below will be changed.
Attachment CIMG0914.JPG not found
Attachment CIMG0911.JPG not found
- russellm
03 Sep 2013 13:17
Paul, the bike is looking good! I finally found a swingarm, should be here in two weeks.
Cheers
Russell
Cheers
Russell
rm
03 Sep 2013 17:41
congrats on your progress sir!
- 808rob
06 Sep 2013 00:39
so i just recently picked up 1979 kz1000 ltd kwaka myself. i dont really like the stock swing arm much and was wanting something a lil bit more modern and would give the bike a blended look of modern cafe racer. been reading and im guessing alot of people like the suzuki arms. my kwaka is chain driven. anything that would be simple to bolt on with minimum fabrication. THANX
06 Sep 2013 11:41
808rob
97-03 gsxr 600 arm has no upper brace.
92 gsxr 1100 arm no upper brace.
you wannna go dual shock or mono?
- 808rob
07 Sep 2013 01:28
hey Leon. i was wanting to go dual just because the dual still gives it "that look". mono might be a little bit too modernly sporty for me. when you say no upper brace. what does that mean for me? less bolts to put on or weak rear end? thanx for the tips.
Rob
Rob
- 808rob
07 Sep 2013 01:33
what kind of work would i have to do for the gsxr arms with mono shocks?
- Paulb450
09 Sep 2013 03:54
Been having a nightmare getting E-bay deliveries through, Offset sprocket and chain still not arrived. The Mikuni,s arroved, unfortunatly the E-Bay seller forgot to pack the Filters and the Rubber intake manifolds into the box so my progress is at a standstill.
Attached pics of the carbs, cant wait to get them on!
Attachment CARBSOUT.JPG not found
Attachment CARBSIN.JPG not found
- Paulb450
09 Sep 2013 03:57
808rob
These two pics will explain the brace on the swingarm, the black swingarm is a busa arm with brace and the silver one os from a zx6r made with no brace. Should clear the difference for you.
The key difference between the mono shock and the dual shocks is how you mount them, the Mono shock means welding your frame to create shock mounts while using the dual shocks means you can use existing mounts on the frame and aluminium weld mounts onto the swingarm. Thats the option I chose because its the look i want from the build.
Attachment BUSAARMWITHTOPBRACE.jpg not found
Attachment swing20arm.jpg not found
