What is it? Z1 or a KZ?
- Kidkawie
- I bleed premix
Re: What is it? Z1 or a KZ?
26 Mar 2013 10:23 - 26 Mar 2013 10:25
Doesn't the KZ-900 have extra frame bracing?
Besides that, looks like a Z1 tail and forks. A Z1 tank has the bottom ridge/seam towards the inside of the tank, not on the outer perimeter. But with all the parts that can swap, only the numbers will tell you what you have. You can put all the Z1 parts on a A4 frame, at the end of the day it's still a 76 KZ.
Not a bad looking bike, don't like mags tho.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 26 Mar 2013 10:25 by Kidkawie.
The following user(s) said Thank You: zoro, wireman
- zoro
26 Mar 2013 11:36 - 28 Mar 2013 02:53
edit
GHOSTRIDER,1980,KZ1000ST
Last edit: 28 Mar 2013 02:53 by zoro.
- Kidkawie
- I bleed premix
26 Mar 2013 11:48zoro wrote:Thats been asked, his response was "It's fine"...Maybe a Z1 with mods for disc brakes? He aint come around since I asked him if it was a stolen bike...heres the link... www.kawasakimotorcycle.org/forum/vintage...caliper-rebuild.html650ed wrote: Looks like a bunch of parts cobbled together. What's the deal with that rear brake line? :blink:
The guy was asking a question. I don't see a need to "call him out" or create any internet drama.
Looks like you need to study up on these bikes since you thought the forks were KZ.
1975 Z1 900
2004 KX125
2004 KX125
- trianglelaguna
26 Mar 2013 12:10
this fukin place
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
26 Mar 2013 12:12
by this point in that bikes life...it is many bikes..as are most by now...3 decades on...anyways ,,,and this will ruffle feathers fo sho...kz-z1-1000-900...same bikes.....kz900-z1900 so darn close and really the z1 changed every run off the line itself some...900=900
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- zoro
26 Mar 2013 12:51Have you ever seen any Z1 forks with twin calipers under the lowers? I see a definite need on a possible stolen bike...Read all the threads he's started, why else would someone refuse help in posting VIN numbers?Kidkawie wrote:zoro wrote:Thats been asked, his response was "It's fine"...Maybe a Z1 with mods for disc brakes? He aint come around since I asked him if it was a stolen bike...heres the link... www.kawasakimotorcycle.org/forum/vintage...caliper-rebuild.html650ed wrote: Looks like a bunch of parts cobbled together. What's the deal with that rear brake line? :blink:
- wireman
26 Mar 2013 13:05
Yes Ive seen z1s with dual discs,that has the sticker on caliper like a z1 caliper has on that side.
Somebody just spun those forks around to put them on rear .
Its not a big deal :laugh:
- pig9r
26 Mar 2013 13:09Have you ever seen any Z1 forks with twin calipers under the lowers? I see a definite need on a possible stolen bike...Read all the threads he's started, why else would someone refuse help in posting VIN numbers?[/quote]zoro wrote:
Couldn't the forks be swapped so the mounts are on the rear???
Why would someone possessing a stolen bike post pics of it on the internet???
- Kidkawie
- I bleed premix
26 Mar 2013 13:16zoro wrote: Have you ever seen any Z1 forks with twin calipers under the lowers? I see a definite need on a possible stolen bike...Read all the threads he's started, why else would someone refuse help in posting VIN numbers?
I probably have.
Z1's came with a dual disc option, and the fork legs are symmetrical so you could just turn them around.
Get off the guys back for not wanting to post his VIN. Alot of people dont, doesn't mean they f-ing stole it.
Stop causing drama.
1975 Z1 900
2004 KX125
2004 KX125
- wireman
26 Mar 2013 13:21 - 26 Mar 2013 14:15
I read your post on the other site,Im a member over there also but never post for this exact reason! :sick:
I don't care what the vin number is on the frame as he said its a z1 front end with newer wheel and brakes.
The 73-75 z1 front end had the reflectors on the forks,kz series bikes did not.
Its a 4 bolt hub/rotor set up on the bike which makes it a 76-newer front rim ,the rear disc brake wire wheel didn't come out till 77 and ended in 78 on the 1000.
Rear caliper looks to be 79-80 1000 ltd to me
Brake rotors are drilled in stock 79-80 ltd pattern,still not sure about extra holes around rivets.
This is my old 74 z1 900,yes it began its career in late 1973 as 74 z1 bike.
I put rear suspension/brakes and front end from a 77/78 kz1000 A series bike on it,do you want to know the serial number off the frame?
Attachment z1-0668a15e9d2f4eac12f2d0e9ca39dbb9_2013-03-26.jpg not found
Last edit: 26 Mar 2013 14:15 by wireman.
- wireman
26 Mar 2013 13:29 - 26 Mar 2013 13:31
Well hell now you've got me on a roll here! :laugh:
Heres the reproduction caliper for the dual disc upgrade on the z1,its the one that goes on right side when calipers are mounted in front .
It goes on left side when legs are reversed.
Do ya notice the allen head bolts in place of hex head bolts?
People on that site should really do some research before posting things they don't know
Attachment z1dualcaliper.jpg not found
Last edit: 26 Mar 2013 13:31 by wireman.
- Kidkawie
- I bleed premix
26 Mar 2013 13:47wireman wrote: This is my old 74 z1 900,
You stole that. Confess! Where's the sales receipt?
1975 Z1 900
2004 KX125
2004 KX125
