zx6r swingarm
- benhurmx
zx6r swingarm
13 Mar 2012 20:59 - 27 Mar 2012 17:55Hi all,
I finally started working on the swingarm upgrade. It is a zx6r 03 swing, the pivot part was shortened and special spacers were fabbed to work with the KZ axle( Thanks to Leon Blackbanshee), works perfect. SInce i intend to go with dual shocks, i have a problem fitting the right shock since the rear caliper is in the way.
Any suggestions ?
Thanks
Last edit: 27 Mar 2012 17:55 by benhurmx. Reason: Icon Change
- ramtough_63
Re: zx6r swingarm
13 Mar 2012 21:29 - 13 Mar 2012 21:31
That is a common problem when trying to mount shocks since you have come this far
i have a theory that if you were to have a brake are made just like the one you have only backwards the caliper would mount underneath and still be an easy install
Essentially the slot on the other side so it would be upside down when mounted
HEY LEON or LES help me out here I think it will be a good fix!!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 13 Mar 2012 21:31 by ramtough_63. Reason: wrong word
- ramtough_63
Re: zx6r swingarm
13 Mar 2012 21:33
I have one of Leons swingarm mods as well but I went crazy amd did the monoshock
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- ramtough_63
Re: zx6r swingarm
13 Mar 2012 21:46Attachment brakemount.jpg not found
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- benhurmx
Re: zx6r swingarm
14 Mar 2012 00:00
are we talking about making a new custom mount, or reusing the same one ?
- ramtough_63
Re: zx6r swingarm
14 Mar 2012 00:10
making a new one just backwards. i don't think it would bev that tuff for a couple of the really talented prople on this site.
I'm sure a local machine shop could hook you up as well
it would be right and servicable.
are you having shock mounts welded on? or is that done cant tell from the pic
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- benhurmx
Re: zx6r swingarm
14 Mar 2012 00:22
I will have shock mounts welded on, i will try to use zrx shocks. How difficult was your monoshock setup ?
- ramtough_63
Re: zx6r swingarm
14 Mar 2012 00:36
I am sure there are other brake mounts you could make work maybe somebody else has a sugestion but I think whoever does your shockmount could make you a new bracket since thats all you need. you already have the brakes
The Mono ended up a little more involved than I thought it would due to my lack of fab experience. I decided to go with rearsets because in my haste I cut the rear brake boss off to get the swingarm in instead of slowing down and analyzing the situation I had a cut off wheel and got cut crazy lol
all I had was
hand tools a cutoff wheel and a lincoln mig welder did it in my daughters garage.
I looked at a couple posts on here OMR had the most complete step by step so I kind of copied it
LES has a bolt on set up he designed not sure if he is making any the ZX swingarm seems to have less angle than others is why I chose to use the T bar route
not sure how far back in my build thread but I have alot of pictures and more if you need (its toward the end)
all I had was
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Re: zx6r swingarm
14 Mar 2012 13:33
looks like custom bracket time :evil: .
- dsmking
Re: zx6r swingarm
14 Mar 2012 15:41
moto-madness.com/catalog/index.php?main_...nfo&products_id=1236
Check these out, they are for a duel caliper but I bet u could find one for a single. This would be the route I would go.
live fast die young.
- benhurmx
Re: zx6r swingarm
14 Mar 2012 17:18dsmking wrote: moto-madness.com/catalog/index.php?main_...nfo&products_id=1236
Very interesting, i can just use the lower one. The only thing is the problem of the pads hitting each other after a certain wear but no biggie. Very strong rear braking with 4 piston caliper. Thanks.
- dsmking
