1982 KZ550 A3 - Master Cylinder
  • Ixer
  • Ixer's Avatar Topic Author
Re: 1982 KZ550 A3 - Master Cylinder
19 May 2011 15:27
#452127
That looks VERY similar to the one a local shop carries, I wasn't too impress with the mounting bracket with that one, the plastic mounting clamp looks like something a huffy from 15 yrs ago would have. I was also told it wasn't rebuildable and that it "should" last a couple of years.
'82 KZ550 A3 - First bike, Attempting to put it back together after sitting for the last 12 or so years.
  • loudhvx
  • loudhvx's Avatar
19 May 2011 15:55
#452139
If the clamp is plastic, then I'd pass on it too, but my catalog says "alloy body".
  • mjg15
  • mjg15's Avatar
19 May 2011 17:08
#452152
I've seen used Brembo stuff on Ebay, they come on Ducati Monster 620 w/single disc.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Ixer
03 Jun 2011 22:37
#455255
Just a quick update, it looks like the master cylinder i bought off ebay is going to work. The stock brake hose bolted right up to it, bled it and i have front brakes!
I ended up with the black one with 12.7mm piston.
Also fired it up again tonight and let it run for a bit, I kept having issues with it not wanting to take ANY throttle. This time i just let it run for a while and it started taking throttle at half choke, after running a bit longer i dropped the choke off and it winds right up. I guess its just VERY cold blooded. Still need to pull the carbs back off and set the floats (the correct way, clear tube) then its tires and installing the new rear (harley sportster) shocks and it should be ready to ride.
  • brooks22
  • brooks22's Avatar
13 Jun 2011 17:59
#457052
hey lxer
sound like you had a run around. I have a 82 kz550c and need to replace my front master as well, where did you get yours and any recommendations? what mods did you encounter? thanks
  • Ixer
13 Jun 2011 20:09 - 13 Jun 2011 20:10
#457064
this one:
cgi.ebay.com/ebaymotors/FR-BRAKE-MASTER-...b7c6#ht_12120wt_1165
The only modding required is going to be the stop light switch.
I do have a SINGLE caliper front though, if you have the double i'm pretty kaw still makes rebuild kits.
Last edit: 13 Jun 2011 20:10 by Ixer.
  • brooks22
  • brooks22's Avatar
13 Jun 2011 22:20
#457104
i have a single caliper front brake only as well, so only one brake hose going on for me as well, how has this worked for you so far? what did you have to do to get the stop light switch to work? again your wisdom is much appreciated
  • brooks22
  • brooks22's Avatar
13 Jun 2011 22:36
#457105
how come you didnt go with this one:
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...X:IT#ht_22232wt_1167
noticed the one you chose was the XT model, what made you get that one? i want brakes to:)
  • Ixer
14 Jun 2011 06:33
#457167
The one i posted most closely matches the specs of the stock MC, 12.7mm piston. The grey one is for a dual caliper setup. I havent gotten around to messing with the brakelight switch yet.
  • tooocool49723
  • tooocool49723's Avatar
15 Jun 2011 21:04
#457492
Well this sucks! Mine went out last week (leaking fluid, no pressure, etc.) and now I can't get a rebuild kit for it! :(
So who can I get to e-mail some of these kit manufacturers and stir up some demand for a kit?
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
  • Dale65
  • Dale65's Avatar
  • 1981 KZ 550 LTD
25 Jun 2011 15:14 - 25 Jun 2011 17:58
#459310
Whatever ya'll do, don't buy this one. Total piece of junk! Couldn't even get it to hold fluid. Also beware it comes in different colors. The brake light switch they sent with it didn't even fit.
Attachment JunkMC.doc not found
The whole reason I looked up this thread was to figure out what to get to replace it. Didn't want to buy another piece of junk. I settled on this one.
New MC
Sold by the same guy that you bought yours from lxer, and it had good reviews and looks good on clubman bars, which is what I've got.
1981 KZ550 LTD stock for now, but soon to be a cafe racer.
Last edit: 25 Jun 2011 17:58 by Dale65.
25 Jun 2011 23:13
#459370
Here's a NOS unit (part #43015-1051) that just came up on eBay for $100 "Buy It Now." Sounds like a bargain!
cgi.ebay.com/ebaymotors/Kawasaki-NOS-KZ-...fPartsQ5fAccessories
