1982 KZ550 A3 - Master Cylinder
  • Ixer
  • Ixer's Avatar Topic Author
Re: 1982 KZ550 A3 - Master Cylinder
01 May 2011 21:53
#448148
Master Cylinder Piston - Kawasaki - KZ750 KZ650 KZ550 KH400 KZ400 KZ1000-A2
43020-1026
OEM: 43020-1026
According to Kawasaki parts, that p/n is for an A1. The A2-A4 needs p/n 43020-1027
'82 KZ550 A3 - First bike, Attempting to put it back together after sitting for the last 12 or so years.
  • wireman
  • wireman's Avatar
01 May 2011 21:55
#448149
thats what z1 lists for the a3 anyway :blink:
  • Ixer
01 May 2011 21:58 - 01 May 2011 21:59
#448152
I know, i keep running into this. It's VERY frustrating, but I guess this is the fun part of restoring. The treasure hunt for parts.
Last edit: 01 May 2011 21:59 by Ixer.
  • wireman
  • wireman's Avatar
01 May 2011 22:06
#448155
maybe try calling z1 and see what they think ;)
  • Ixer
04 May 2011 10:50
#448785
In email chats now, will keep updated for others..
  • H1Vindicator
  • H1Vindicator's Avatar
04 May 2011 11:04 - 22 Jan 2013 01:12
#448788
Last edit: 22 Jan 2013 01:12 by H1Vindicator.
  • Ixer
04 May 2011 12:01
#448800
From Z1...This is my first experience with them, but seeing the lengths they gone to for someone that hasn't ever ordered from them I will be ordering parts from them the future.
"Hi Robert,
So it does appear that our listing was wrong and has been corrected. The 43020-1026 fits only 1980 kz550 which has the trapezoidal shaped reservoir and was on many other early models.
It looks like the 43020-1027 is for the later 550’s having the long rectangular reservoir.
The 1027 has been discontinued from Kawasaki and looks to be hard to find. I checked ebay and several of our resources with no luck. Is the 1026 one of the ones you have tried? It does measure ½” in diameter but I suspect the length is wrong. I will continue to work on this but unfortunately right now I don’t have a solution."
So the hunt continues....
  • Ixer
18 May 2011 14:56 - 18 May 2011 14:57
#451918
Ok so a rebuild is out of the question, that is unless someone has a warehouse full of NOS Kawi parts.
So the hunt is on for a universal master cylinder, so a few questions.
I know i need to match the stock piston size (1/2" or 12.7mm), resevoir orientation (flat), banjo bolt size (10x1.25mm), mirror socket, and Handle bar size (7/8")
But what about:
resevoir capacity
piston throw / lever throw
matching the stock lever
Thanks,
Last edit: 18 May 2011 14:57 by Ixer.
  • Ixer
19 May 2011 09:23
#452066
Please don't fail me now guys....bump
  • martin_csr
  • martin_csr's Avatar
Re: -
19 May 2011 11:01 - 13 Feb 2013 13:04
#452075
Last edit: 13 Feb 2013 13:04 by martin_csr.
  • Ixer
19 May 2011 11:11 - 19 May 2011 11:13
#452076
here are the ones i'm looking at:
cgi.ebay.com/ebaymotors/FR-BRAKE-MASTER-...fPartsQ5fAccessories
They list this one as fitting "my bike" but the piston is 14mm where as mine is 1/2" (12.7mm), they also say its for a dual disc setup where as mine is single disc. I assume the piston size is the difference.
Here is the one that "matches" my specs, best i can tell. I was just worried about the resevoir and throw not being larger enough to fully engage the brake.
cgi.ebay.com/ebaymotors/FRONT-BRAKE-MAST...&hash=item19c59614e5
same with this one
cgi.ebay.com/ebaymotors/FR-BRAKE-MASTER-...&hash=item1c1bdf32ae
I hate trying to buy parts on the internet, i really do like physically comparing things. This is especially difficult as this is all NEW territory to me, as far as motorcycles are concerned.
Thanks for the response!
Last edit: 19 May 2011 11:13 by Ixer.
  • Motor Head
  • Motor Head's Avatar
19 May 2011 11:28 - 19 May 2011 11:29
#452079
Have you looked and seen that the rebuild kit 43020-1027 from KAW is NLA, but has this list of bikes that it fits? Maybe you can search for a kit this way from another model?
Last edit: 19 May 2011 11:29 by Motor Head.
