1982 KZ550 A3 - Master Cylinder
  • Ixer
  • Ixer's Avatar Topic Author
Re: 1982 KZ550 A3 - Master Cylinder
01 May 2011 10:29
#447990
So kawasaki no longer makes a replacement for this part, correct?
'82 KZ550 A3 - First bike, Attempting to put it back together after sitting for the last 12 or so years.
  • martin_csr
  • martin_csr's Avatar
Re: -
01 May 2011 11:27 - 13 Feb 2013 13:03
#448002
Last edit: 13 Feb 2013 13:03 by martin_csr.
  • Ixer
01 May 2011 12:12
#448013
This is turning out to be a nightmare and a half....lol
The Kit that Z1 says will fit that bike in the post, does not say not will fit on their site.
"Front master cylinder Rebuild Kit - Kawasaki KZ550 ZX550 KZ700 VN700 ZN700 KZ750 VN750 ZX750 KZ1000 KZ1100 ZN1100 ZN1300
KL32-8061
Equivalent to OEM: 43020-1028 43020-1079
Fits the following front master cylinders: Kawasaki KZ550H (82-83) ZX550 (84-86) KZ700 VN700 ZN700 KZ750F1/L3/N1/N2/R1 VN750 (86-90) ZX750 (83-85) KZ1000J3/R1/R2 KZ1100B2/D1/D2/L1 ZX1100 (83-84) ZN1100 ZN1300 (83-86)
$31.10"
I promise i'm not trying to be argumentative, just frustrating.
I've been to 4 local cycle shops, one that stocks "every" kit for the kaw's and compared mine to each of them. Many, Many emails to multiple companies and no one seems to able to match a kit for my bike.
I TRUELY appreciate all the help from everyone!
Thanks again,
Rob
  • martin_csr
Re: -
01 May 2011 13:05 - 13 Feb 2013 13:02
#448031
Last edit: 13 Feb 2013 13:02 by martin_csr.
  • Ixer
01 May 2011 13:12
#448032
i plan to have stainless line made to replace the stock one.
I also will be rebuilding th caliper (have the seals already), front pads, & rear shoes.
I do appreciate the info, i really do!!!
Thanks,
Rob
  • martin_csr
Re: -
01 May 2011 13:16 - 13 Feb 2013 13:02
#448034
01 May 2011 13:27
#448036
I've searched all my parts sources for 43020-1016; 1020; and 1027 and I struck out. You may find (as Martin suggests) that some of the rubber bits from other kits will work properly on your MC. Unfortunately, determining which ones will work may be rather difficult unless you have funds to buy a bunch of different kits to compare their primary cups, etc. I'm surprised that the kits don't seem to be available NOS or aftermarket. Maybe ask one of the kit suppliers or manufacturers if they have specs you could use to cross reference the rubber bits? Sorry I can't be more helpful. Ed
  • Ixer
01 May 2011 21:16
#448133
The dust boot is still produced (i have one on the way), i just really wanted to replace the piston, spring, and stop washer also.
Thanks again for everyone's help!!
-Rob
  • wireman
  • wireman's Avatar
01 May 2011 21:45
#448143
z1 enterprises shows the piston assembly for $38 and change ;)
  • Ixer
01 May 2011 21:46
#448144
Link?
P/N?
  • wireman
  • wireman's Avatar
01 May 2011 21:49 - 01 May 2011 21:50
#448146
Last edit: 01 May 2011 21:50 by wireman.
  • wireman
  • wireman's Avatar
01 May 2011 21:52
#448147
