Speed Triple Single Sided Swingarm Installation
- porchev914
Re: Frame Jig and SSA Installation
20 Feb 2010 19:53
And the semi final product. Now I'll drill holes in the cross braces for leveling/jack screws (and maybe anchor points for non destructive stress testing?) and start fabbing the front and rear support stand offs.
FRANKEN Z!
- porchev914
20 Feb 2010 19:55 - 20 Feb 2010 21:16
Yeah Plummen, its fluxed core mig. I ran out of argon but I still wanted to put the jig together. I've never run flux core through my little mig. I can officially say that I don't like it and will get my bottle filled Monday. This crap splatters ALOT
FRANKEN Z!
Last edit: 20 Feb 2010 21:16 by porchev914.
- porchev914
20 Feb 2010 20:05
jus1975 wrote:
I'm with you brother, I can't wait either!cant wait to see the finished project
FRANKEN Z!
- porchev914
20 Feb 2010 21:15
The '08 Triumph swingarm measurements are as follows -
Pivot centerline to axle centerline = 19 13/16"
(compared to 19 5/8" as measured on stock swinger, still mounted on frame)
Triumph swingarm width at pivot = 11 3/16"
Swingarm axle width inside flange heads = 13 1/4"
Weight (as measured on my absolutely precise bathroom scale) = 34.5 lbs
FRANKEN Z!
- jus1975
- www.tripleaperformance.com
21 Feb 2010 07:25
After looking at that swingarm. Im wondering if that thing was used in the design of some of the agtermarket big tire single sided swingarms. Its giving me ideas.
- testarossa
21 Feb 2010 07:50
porchev914 wrote:
That flux core does have it's place, to remind you how much you like using solid mig wire! Flux sounds like a drive by shooting while your welding.
Anyway, Adam, nice work there. I must say that you are forcing me to step up my game here.
jus1975 any idea who makes that second swingarm in your pictures? That is giving me an idea for testarossa's streetfighter 2.0. Me likee!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
21 Feb 2010 11:11
Those sure are nice looking custom arms jus1975; I'd hate to see what their fabricators charge for them :whistle:
And yeah Josh, that flux core is a back up, rough welding wire AT BEST. Maybe it has something to do with the fact I got it at HBF? But probably not! :laugh: No need to step up your game Testarossa, just finish your build like you planned. Like you said, there is always version 2.0! Besides, this is pretty basic stuff so far. I believe I'm going to go ahead and make a fixture to mount the frame sideways by the swingarm pivot and a place to bolt the fram jig to the floor. That way I can quantify the torsional flex of the frame before modification. If I'm really ambitious I could check the torsional stiffness after each mod to see how well it works :ohmy:
My offer still stands to any locals that would want to help with some frame testing.........?
FRANKEN Z!
- porchev914
21 Feb 2010 22:48
I just about finished my frame jig base today. Got the holes drilled in the transverse supports and some 1/2" fine pitch bolts and jam nuts for the 4 corners. I also painted the jig base. I decided to use flat white for the paint so that I can make marks or notes with a sharpie on the jig, then paint over when I need to "clean the slate".
FRANKEN Z!
- porchev914
21 Feb 2010 22:53 - 22 Feb 2010 19:10
Just to show those following this thread the size difference between the stock swingarm pivot and the Triumph SSSA pivot: The stocker easily fits inside with plenty of room to spare!
FRANKEN Z!
Last edit: 22 Feb 2010 19:10 by porchev914.
- porchev914
21 Feb 2010 23:06
One more thing I'd like to do during this build is to document the weight of parts that I take off and the those that I install to see what net loss (or gain? :blink: ) I will achieve. The SSSA weighed in at 34.5 lbs sans wheel and tire. The stocker with wheel and tire weighed in at 64.5 lbs. So as long as the Triumph wheel and tire are under 30 lbs, I'll have lost some weight!
Now the frame weighed in at 53.5 lbs, but I'll be removing less and adding more, so I don't expect to loose much weight here. Now I just need some paint remover and an argon refill.....
FRANKEN Z!
- jus1975
22 Feb 2010 07:05
I dont know if you guys know this or not but I have a bike shop. I sell these arms. I specilize in drag and custom sport bikes. Although nobody locally has purchased one of these arms, Ive mostly just dropped shipped them straight from the manufacturer.
- porchev914
22 Feb 2010 19:18
FRANKEN Z!
