turbo z1r with underbraced stock swingarm.
27 Jan 2009 11:46
Re: turbo z1r with underbraced stock swingarm.
27 Jan 2009 11:49
- kawtoy
27 Jan 2009 13:15
Yummy!
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
27 Jan 2009 15:28 - 10 Feb 2009 18:53
Last edit: 10 Feb 2009 18:53 by 531blackbanshee.
27 Jan 2009 15:30 - 28 Jan 2009 11:21
Last edit: 28 Jan 2009 11:21 by 531blackbanshee.
- PLUMMEN
27 Jan 2009 16:30 - 28 Jan 2009 12:58
531blackbanshee wrote:
can the front of the brace be raised up a couple inches or is it a chain issue?
Last edit: 28 Jan 2009 12:58 by PLUMMEN.
28 Jan 2009 07:42
i did not build the swingarm on the black z1r above,i just posted the pic to help visualize.
that is where the chain clearance gets close.it could probably be raised a little but you would need to have the gaering and chain in place to see just how close you can get it and still allow for suspension movement.
28 Jan 2009 07:48
- PLUMMEN
28 Jan 2009 09:34 - 28 Jan 2009 09:40
im just using this as an example but is it possible to build a brace that fits just above the level of the chain and follows same level as swingarm with a little kick/offset up in the front towards pivot tube then loops around to the other side ? i want people to have to look a little bit to notice the bracing.does this make sense?
Last edit: 28 Jan 2009 09:40 by PLUMMEN.
28 Jan 2009 09:47
plummen,the picture is what i have drawn so far(clicking it makes it bigger and easier to see).without the front part where the air/bottle will go(i need some dimension's)and i haven't added the bungs for a possible wheelie bar mount.i could use two bungs per side on the back of the brace and have some bolt on wheelie bar brackets.the welded on brackets "offend my sense of neatness".which is why i have been trying to figure out how to mount it without just having some brackets that look like an after thought hanging down when the bar is not on.does the pic look anything like what you thought it should?
- PLUMMEN
28 Jan 2009 09:50
ive got a rough picture to fax to you .its got an idea for the bar mounts i was talking about on the one side,but i think i like youre idea of the mount better.is it safe to send to ya?
- PLUMMEN
28 Jan 2009 09:53
allright i faxed it to ya
