turbo z1r with underbraced stock swingarm.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: turbo z1r with underbraced stock swingarm.
10 Feb 2009 19:24
#263665
definately in the ball park,can we loop the front of brace to other side of arm?B) B) B) B) B)
  • 531blackbanshee
  • 531blackbanshee's Avatar Topic Author
  • Vendor
  • Vendor
11 Feb 2009 06:05 - 11 Feb 2009 06:08
#263767
yes we can.if we are going to put a bottle mount we can use that to connect both sides and create a little more structure in the front where the gusset normaly is as well.
is the back part agreeable?
Last edit: 11 Feb 2009 06:08 by 531blackbanshee.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Feb 2009 11:07
#263822
yes sir you are a swingarm god!:laugh:
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
14 Feb 2009 22:15
#265124
more, more, more, more!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • PLUMMEN
  • PLUMMEN's Avatar
15 Feb 2009 07:42
#265140
-KR
ok, but i warn you ive got a full library of homer simpson action shots !anything in particular you want to see?:laugh:
  • 531blackbanshee
  • Vendor
  • Vendor
15 Feb 2009 17:12
#265245
here it loops over to the other side and is a little more moiwaki'ish.i also need the dimensions for the bottle you plan to use and then i can incorporate it into the design.
  • PLUMMEN
  • PLUMMEN's Avatar
15 Feb 2009 19:44 - 15 Feb 2009 20:58
#265270
now im gonna throw another wrench in the works!:S can we make the highest point of the offset in the front the point where it swings to the other side ?i wish i knew how to draw lines on a computer!:blush: think of it like a piece of conduit coming towards front of arm:its running parrelel to the arm then it kicks up at lets say a 22.5 degree angle to keep it simple then rolls right into a 90 degree bend going under front of swingarm to other side to repeat the process.make sense?;)
Last edit: 15 Feb 2009 20:58 by PLUMMEN.
  • PLUMMEN
  • PLUMMEN's Avatar
15 Feb 2009 19:55
#265272
  • 531blackbanshee
  • Vendor
  • Vendor
16 Feb 2009 06:21
#265331
so actually more like the picture in post #263660 except loop over to the other side and add the upright brace?
i can't draw on the computer either,so i draw on paper then take a picture of the paper then put that on the computer:laugh: .hell i know you can pull that off:P .how about some bottle dimensions,thats going to dictate some of the front of the bracing.
  • PLUMMEN
  • PLUMMEN's Avatar
16 Feb 2009 06:54
#265341
ill try and get dimensions today B)
