GS1100 vs GSXR600 Swingarm
  • supercharged
  • Topic Author
28 Dec 2008 21:04 - 28 Dec 2008 21:11 #255180 by supercharged
GS1100 vs GSXR600 Swingarm was created by supercharged
I had the opportunity to compare the 2 swingarms... since images tell it better than I could... see what you think
Click on image to see better..
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
Last edit: 28 Dec 2008 21:11 by supercharged.
  • supercharged
  • Topic Author
28 Dec 2008 21:05 #255181 by supercharged
Replied by supercharged on topic GS1100 vs GSXR600 Swingarm
Left side
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 21:09 #255182 by supercharged
rear look
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 21:09 #255183 by supercharged
right front
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 21:10 #255184 by supercharged
top view
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 22:25 #255191 by supercharged
GS1100 lined-up in frame
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 22:26 #255192 by supercharged
gsxr600 lined-up in frame
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 22:28 #255193 by supercharged
Tight area around rear master cylinder mount with GS1100
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • supercharged
  • Topic Author
28 Dec 2008 22:28 #255195 by supercharged
GSXR think the rear brake control mount will have to go...
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
28 Dec 2008 23:23 #255198 by donthekawguy
Replied by donthekawguy on topic GS1100 vs GSXR600 Swingarm
The 600 arm is definitely beefy. Looks like it might be a better fit. The only thing is you will have to weld on shock mounts if going with dual shocks. Looks good though.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
28 Dec 2008 23:25 #255199 by KawiConvert
Replied by KawiConvert on topic GS1100 vs GSXR600 Swingarm
Nah, just bend it out of the way :) Pretty cool look at the two swingarms in the frame, how much of a pain is it to fab up a shock mount for the mono shock?
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
28 Dec 2008 23:30 - 28 Dec 2008 23:33 #255200 by BohicaBob
Replied by BohicaBob on topic GS1100 vs GSXR600 Swingarm
You can buy PMC shock mounts that can be welded onto the GSXR swingarm. Jeff at Z1 sells them.
The GSXR swingarm pivot bolt is probably 20 mm in diameter compared the 16 mm for the GS1100 swingarm. A spacer can be made to accommodate fitment of the GSXR swingarm however.
Last edit: 28 Dec 2008 23:33 by BohicaBob.
